Author Topic: What did I fry???  (Read 7590 times)
zap
  • There's an app for that
What did I fry???
« on: November 20, 2010, 01:08:40 PM »
I have a couple of the $10 12vdc 'under cabinet' fluorescent lights from Home Depot, Lowes, etc.  When using AA batteries the inverter is protected from reverse polarity but not when using external power. :'(
I've searched every database I could find but I can't find the specs on this:
A bit hard to make out in the picture:
H           T
8(?). then some number or letter obliterated by the eruption, then what looks like a 2
4DA5AP
Any ideas?
Rover
Re: What did I fry???
« Reply #1 on: November 20, 2010, 01:32:41 PM »
Was it heat sunk (doesn't look like it)?... can you post a picture of the circuit and where it was ? as tight in as you can get
Rover
« Reply #2 on: November 20, 2010, 10:05:09 PM »
might be a voltage regulater ??
« Reply #3 on: November 20, 2010, 10:41:40 PM »
I cross referenced it every way I could think of, with no luck.
May be a house numbered device.
Look inside the others, if possible, and see if they have different numbers.
It is a $10 light?
If the part is not super common, probably cost $10 to get the part in your hand.
zap
« Reply #4 on: November 20, 2010, 11:23:59 PM »
It is a $10 light?
Everything you said G-
I tried every cross reference I could think of... bupkis!
I'll open the other up and have a look.
I would probably never buy the part... too expensive.
I might just head to Dollar Tree and pick up 3 of the LED tap lights, harvest the LEDs and fit those in the housing.
Thanks for the help folks.
« Reply #5 on: November 21, 2010, 02:03:05 AM »
I have a coupla styles of those lights here. made by the same people but one is a few years older then the other one.
This is the older one it has 1 of those parts labeled as 3GA5P
This is the newer one and has 2 of those parts labeled BD237
I suspect that the number on your part is BDA5AP
Also Walmart has those lights for about $7 in the lighting department in with the replacement fluorescent bulbs.
« Last Edit: November 21, 2010, 02:06:45 AM by wooferhound »
wpowokal
« Reply #6 on: November 21, 2010, 02:36:11 AM »
I think Woof gets the award a simple NPN transistor
zap
« Reply #7 on: November 21, 2010, 10:25:11 AM »
Thanks for that woof... your first picture is an almost exact replica.
Allan, the BD237 clearly shows up on Google as an NPN but I couldn't find anything on the 3GA5P.  You're fairly sure it's an NPN?
Not that it matters much.  I only use one at a time plus a recent event caused me to toss most of the 3 dozen or so circuit boards I usually keep around to harvest parts from.  Although I'm certain I could start collecting again ;)
Thanks again everyone!
« Reply #8 on: November 21, 2010, 06:08:57 PM »
got one of these from Walmart and worked fine with a 3.9 amp/hr.----13.5v NiCad until it dropped below working voltage.
and went out but recharged battery and wouldn't turn on.....
BTW it is supposed to be an 8watt so the 3.9 amp/hr should last longer than couple hrs. ?
Madscientist267
« Reply #9 on: December 06, 2010, 04:34:00 PM »
I know this thread is pretty much dead, but wanted to see if I could 'extract' anything from the picture...
Gave it a shot - played with the curves etc in GIMP and came up with these two... had better success making the blowhole stand out than the lettering, but maybe someone can identify it. I didn't have much luck either with what I came up with.
If nuttin else, they shore are purdy... LOL
Steve
« Reply #10 on: December 06, 2010, 10:06:24 PM »
From what I posted above, I would say it's a -B- without even looking at the picture. But those picture sure do look cool !!
yuandrew
« Reply #11 on: December 09, 2010, 01:16:03 AM »
I have one of the older style AmeriTac fluorescent lamps. The transistor on mine is a NEC 2SD882.
RepairFaqs has a schematic of the board.
http://www.repairfaq.org/sam/amtac1.gif
One of the things I liked about the older model is that you can turn up the tombstone shaped rheostat that's behind the switch using a jewler's screwdriver and it will drive the tube harder. Use a MA meter to monitor check the current as you go. If I recall, they only run around 350ma stock which is around 4.2 watts. I brought my remaining one up to 500ma (6 watts) which is adequately bright and it's been working for over 2 years like that now. Try not to go over that because I cranked my first one up all the way to full power and it burned out after half an hour.
zap
« Reply #12 on: December 09, 2010, 09:58:40 PM »
Thanks for that yuandrew!  I'll have to look the specs up and see if I can substitute.
Interesting pics Mad... thanks for the effort!
