Author Topic: Welder-inverter issue  (Read 2790 times)
madlabs
« on: January 21, 2011, 11:20:24 AM »
Hi All,
Well, I kicked down big time and bought myself a brand new Lincoln 140T mig welder. Haven't bought myself a fat new tool for a long time. The thing that sucks is that it is the first piece of equipment I have doesn't like my inverter, a Trace 2512. It welds poorly. The welder isn't pulling more than the inverter can provide, but the arc is erratic and difficult to control. It runs fine on a genny, so I can use it, but...
I have a giant variac (50A). I was wondering if I could run inverter-->variac-->welder and if it might smooth out the modified sine of the Trace. I can't see any way it would screw either piece of equipment to try, but I thought I'd ask here before trying.
Thanks!
Jonathan
Re: Welder-inverter issue
« Reply #1 on: January 21, 2011, 11:31:00 AM »
If you have plenty of power head room you might try running some hefty motor driven device while welding?
A fan or something might help stabilize your output? A flywheel effect if you will.
Check all your connections, too.
Just where I would start.
fabricator
  • My smoke got out again
« Reply #2 on: January 22, 2011, 07:42:37 AM »
I know a guy who had the same problem, his welder is a smaller Hobart though, he uses Toms suggestion, he starts up his large vertical band saw and it welds great then.
hayfarmer
« Reply #3 on: January 22, 2011, 09:01:41 AM »
had the same problem,started a table saw and smoothed out the bumps on a MSW inverter.
« Reply #4 on: January 22, 2011, 03:32:33 PM »
if you can get your hands on a synchronous motor, those work even better.
http://en.wikipedia.org/wiki/Synchronous_condenser
madlabs
« Reply #5 on: January 23, 2011, 10:29:12 AM »
Ok, I'll try running another load. But what about using the variac? Giess I'll just try it  and see.
Thanks!
Jonathan
« Reply #6 on: January 23, 2011, 10:38:51 AM »
Thanks!
Jonathan
The key here is a motor load.
I doubt the variac will help.
It makes a difference.
madlabs
« Reply #7 on: January 23, 2011, 10:44:36 AM »
Thanks for pointing out I need an inductive load. All of my big load devices are pretty much motors anyway. I'll start with a bench grinder. I have some overhead on the inverter, but not too much.
Thanks!
Jonathan
« Reply #8 on: January 23, 2011, 10:47:31 AM »
try boosting the voltage 10% with the varac.
« Reply #9 on: January 23, 2011, 11:20:17 AM »
It's not necessarily inductive that matters: I suspect it works because the rotational inertia is acting as storage smoothing out the power flows as seen by both the inverter and the welder.  Indeed 'flywheel' storage is quite a hot 'smart-grid' topic at the moment.
