If anyone was wondering how to design a Three Phase alternator.
I have a way that i thought i would share with the community.
Just remember 3, 5 , 7, 9, 11, 13...
Thats odd
3 4 3
6 8 5
9 12 7
12 16 9
15 20 11
18 24 13
column 1 is the number of coils desired
column 2 is the number of poles
column 3 is the magnet DIAMETER multiplier
example 1 : Row 3 is a 9 coil 12 pole machine , with a magnet diameter multiplier of 7
example 2 : Row 4 is a 12 coil 16 pole machine with a magnet diameter multiplier of 9
Ok William what the heck is a magnet diameter multiplier ?
it lets you select your rotor diameter and hence your whole machine.
Lets get started , i found some magnets at a good price , that are 1.5" in diameter.
and i can only afford 24 of them.
so that means i'm looking at a 9 coil 12 pole machine.(dual rotor)
In row three is a 9 coil 12 pole machine with a magnet diameter multiplier of 7.
1.5"(magnet diameter) * 7 = 10.5 inches in diameter rotor.
ok Now what??
Rule 1 Your coils shal be twice your magnet diameter.Or there abouts, But i like to make them twice the magnet diameter.
ok thats three inches in diameter. Thats doable because the way i wind coils is with resin or epoxy mixed in when i wind the coil. And they come out thnner for the same number of turns per coil as opposed to a coil with a smaller diameter.
what do we have now..
we have a 10.5 inch rotor diameter with 12 poles on it.( two of them)
we have a stator with 9 coils that are 3 inches in diameter.
How can i check if this actually all fits together ??
I use emachineshop's free online program
If your net speed is good , it works fine.
oh your magnets will come to the outer edge of the rotors.
