I figured that I needed to put the "Treadmill Dyno" thread to rest, but since there are a handful of people that seem to enjoy my project, I decided to make this thread that will house all the new stuff, which there is plenty planned
The old thread:
http://fieldlines.com/board/index.php/topic,144470.0.htmlAfter achieving an impressive 1011 mpg in sub-par driving conditions and a stock engine, this year we plan on taking 1st place. We have the resources (well at least 10% of our competitors anyways) and the smarts, so there isn't much stopping us. I figure this year's car had 1/2 the drag of the 2010 car, so I think we could of had 1200-1300 mpg if our last run was good. I also believe that our porting and polishing actually lowered our 1,500-3,000 rpm efficiency, so we would of been better off with a stock engine (and the tests proved it...).
We are not yet 100% sure yet if we are going to build a new body, but there are many improvements to the various components that we will be doing anyways, starting off with this one:
Larger Version:
http://i55.tinypic.com/34o3e5e.pngThis is going to be our new rear sprocket. Last year's car used a 12:100 chain set up using #35 non-roller chain. Max efficiency couldn't of been higher than ~94%, and probably closer to 90-92%. This year, we are going with a 12mm wide carbon fiber timing belt, which has a max efficiency in the 98-99% range. If we can add 5%, it will be well worth our effort. We are going to build this sprocket ourselves at work (CNC shop) out of a 1" x 19" x 19" piece of 7075-T651 aluminum (good stuff
) It has 180 teeth, which allows for a larger driving sprocket on the engine, which is where we were loosing most of efficiency with the chain. It will weigh 2.2 lbs and be 3/4" thick by 18" diameter.
The belt was just ordered, so it should be here by next week. According to Gates, it can handle 300 hp at 4000 rpm on the driver sprocket..... yeah 12mm wide
This should be completed before school starts.
The next project is a really big one: The Engine. Obviously we can do better than a stock engine, and we can double our efficiency if we do it right. Last year's car car had too much power, so much so that the car did a few moving burnouts during the fuel economy runs at 1/2 throttle (SMV's aren't supposed to get their back ends out
So the solution:
Compared to a stock:
This a a briggs 3.5 hp 148 cc engine that now has a honda gx35 35cc piston in it and had been de-bored and chromed. Due to the extra long stroke, we now have a 53.61cc engine, which makes it easier to have a super high compression ratio. We have plans on making a 13.5 :1 compression ratio, which should raise the thermodynamic efficiency another ~10%.
There have been dozens of plans to make a rocker arm set up of over head valves, but I have a different plan that is very different: Rotary Valve Engine.
Now, you may have thoughts of 2-strokes and sleeve valve engines running in your head, but this is totally different.
http://home.people.net.au/~mrbdesign/PDF/AutoTechBRV.pdf - F1 team that helped develop a modern version of this.
I came up with this idea all by myself, but it took a friend, my brother, and I 6 weeks to find another engine like this.
Basically, it has a rotating pipe that acts like a valve. It has several advantages, some of which include less air flow issues, less moving parts, shorter engine height (big one for us), high compression ratios, sideways exhaust, less friction, and easy to build. There have been people who have made their own versions and once guy actually got better mpg's with the same block and had slightly more hp. He ended up putting 30,000 miles on the engine.
Sealing obviously is the hard part, but I am very confident that we can overcome this, especially with 3,000 psi Teflon and carbon rotary shaft seals (something others haven't tried). The pipe will be the diameter of the socket in the photo. The spark plug is shown too.
Lastly, there are some major plans to do a better job with the treadmill dyno this year, starting with chucking it up in a CNC machine with shaft power and rpm readouts. I also want to get a timing belt on it so there is less issues with that. Last year's tests were majorly skewed by the limited power of our Bridgeport, so the RPM's were off. Maybe direct drive if we are ambitious straight from the treadmill motor to the engine is in store. Our new room has a high temp exhaust fan, good for 1500F, so engine testing will be a piece of cake ( especially while classes are in session
