They are almost finished rebuilding my shop from the tornado damage. I'll be starting on a "new project" when it's finished and wired. My game plan is to build a large VAWT. I'm going to take two 55 gallon barrels, weld them end to end and then cut them in 1/2 and use about a 17% overlap with a 4 foot steel circle at the top and bottom to capture the wind. Then add another stack above that set to the turbine. I'm trying to decide what bearings to use for the shaft. Part of me wants to go to the local Agri-Supply store here in the states and use axle stubs and bearings with a 2 inch DOM tubing for the shaft. Then I'd have to make an adapter of some sort to run the gearing off the end through the axle nut end. Basically, build a long axle to mount it on then make an adapter to run a shaft for running my load from the bottom end through the end the bearing grease cap would go on. The other option is to use flanged bearings. The second option I think will cost more. With the first Agri-Supply axle ends I have my choice of axle bearing sizes from the 1000 Pound rated ends up to around the 18,000 Pound rated ends. I realise these axle ends are normally used with the bearing load at a totally differant angle than the complete "side load" I'm going have them running at. What size axle ends would you folks run? Right now I'm going to use the mill to pump water for a ground water A/C system I'm bulding and later add a small generator to it.
