Author Topic: Replacement diode for pv panel?  (Read 6585 times)
Simen
  • Country: no
  • Grimstad, Norway
« on: August 10, 2011, 02:31:14 PM »
I've just got a GV 120W panel (12V) cheap with one fried (shorted) bypass diode. The diode are marked "ST 1010", but i can't find much data for it...
I do however, have some MBR2045CT (Dual) Schottky diodes from an old computer psu, rated 45V, 20A. (TO-220)
In short; Can i use those?
BrianSmith
Re: Replacement diode for pv panel?
« Reply #1 on: August 10, 2011, 06:11:10 PM »
I would think so, but at 10 amps you will need a good sized heatsink.  Is the other one a TO-220 as well?
Simen
  • Country: no
  • Grimstad, Norway
« Reply #2 on: August 11, 2011, 02:32:20 AM »
No, the original looks like a typical round 4-5A diode. And i mentioned the wrong type number for the original diode! The right number are "SL 1010"...
Normally i manage to find data sheets on the net, but this one eludes me, so i think it's special made for the junction box that is installed on the panel.
Here's the junction box: (which comes with diodes installed)
http://www.te.com/catalog/bin/TE.Connect?S=25224&M=PPROP&P=&BML=10576,17560,17838,23345,25159&LG=1&PG=1&IDS=371355,371357,371358,371359,466063,371348,371362,371354,371363,371367,371364,466064,466445,466446,466290,466291,466292,466293,466294,466295&N=13
But then let me ask this;
What kind of dioes are normally used in solar panels?!
« Reply #3 on: August 11, 2011, 11:58:16 AM »
The factory diode is 10A 1000V.
Got " A " 12V panel means it is a 12V system to me.
Bypass diodes serve no purpose in a 12V system.
I usually tell people to cut them out before they cause headaches.
This one already caused a headache, but you know what it is, that it serves no purpose in a 12V system, and that it can be removed.
Cut it off.
Cut the other one off too.
Problem solved.
Simen
  • Country: no
  • Grimstad, Norway
« Reply #4 on: August 11, 2011, 01:32:25 PM »
;D
Yes, it's for a 12V system (sorry; a bit imprecise there...) ;), and i know those diodes are there for bypassing partly shaded panels when several panels are in series... :)
I've already changed the diode with the one i had, and it seems ok; no temperature difference between the diodes when connected to battery, short circuited, or partly shaded... So i'll leave them in until they act up... ;)
Thanks! ;)
Algie
« Reply #5 on: September 01, 2011, 11:36:44 AM »
since there shall be a current drop of around 100mA cause of the diode.
if i had to make a solar controller between the panel and batteries instead of diode will there be a back voltage from the batteries to the panel when panel is shaded ?????
thanks
« Reply #6 on: September 01, 2011, 09:41:48 PM »
http://www.alibaba.com/product-gs/278186375/High_Voltage_diode_SL1010_10mA_10KV_.html
The diode by itself is here. 10ma at 10KV max reverse voltage.
That is probably a lightning protection diode. Does the panel look like it took a hit?
Simen
  • Country: no
  • Grimstad, Norway
« Reply #7 on: September 02, 2011, 02:59:22 AM »
No, no burn marks, except where the diode was fastened; the diode had shorted out and one leg was poorly connected. :)
