Halfcrazy,
I don't understand your argument as being useful to anyone interested in their turbine. Anyone designing a turbine to start at 7mph is not terribly serious about performance anyway. If your machine is dreadfully matched, then you need someone else's help to make it work decently.... like a mppt solution.
Logic..... working on a turbine starting to stall at 9mph ........... "This same turbine direct to battery's falls flat on its face above 9mph and seems to stall at 600 watts until"..... more like a boat anchor.
I built my two 4M machines for less than 800 dollars for both (not one). I don't need a 90 foot tower, and I am not interested in a 7mph cut in (more like 13mph with boost).... in short, I don't have any where near the problems you would have to match a fair part of the curve. We claim a linear to cubic relationship, but due to the nature of the tsr to wind, it seems nearer to a square function. There is a lot of slippage if you design for the right part of the curve. read Flux's matching the load to get a better perspective.
A 12m tower is far more than I need, and it still costs nothing for 12m irrigation pipes galvanised and 8" in diameter. For the cost of 2 classics I could easily build 4 mills.
I say again, a mppt will only help significantly if your matching is poor anyway..... yours clearly was. The AWP up on the hill is putting an easy 24kwh/day for 3.6m. It is 1000 feet above the surrounds, and does this easily each day (annoy's me down here really...) so every situation is different. It would not help the AWP, as it is flat out all the time anyway, it won't help mine much, as they are well matched and furl early, it will help you significantly, as your matching has to be poor for a 7mph cut in.
There are a lot of things that will dictate the viability of a classic or any other solution between the stator and the batteries. But if you deliberately design a mill for poor performance in order to have to use electrickery (and I'm familiar with that enough that it does not scare/faze me), then good for you. I suspect real windmill folks like Flux roll over in pain when they read of 7mph cut ins.....which by definition is aiming for very very poor matching.
If you do this , it has to be for a reason......sedate mill, don't need more power as a big mill taking it easy puts out far more than a smaller mill running well as a rule..... or just copying someone else who had different needs to you apparently.
Your argument is fair comment for your case and others like it, but not useful for a lot of other cases.
In short.... I think this is less than useful commentary: "I think the only legitimate argument I have heard so far is "I do not want electronics between my turbine and battery" As for Chris saying it is cheaper to build a bigger or second turbine I beg to differ I will gladly buy a 90ft tower and a 17ft machine every day for the street price of a Classic 150. Better start building Chris I think I can sell 20-30 17ft turbines a month for $750 with tower, guys and anchors oh and shipping."
For me.......... Chris is right. I can BUILD not buy... a decent mill for $400 including tower. In my case you are clearly wrong. In other cases, if they built it properly and made it a foot bigger they could probably match a MPPT, and if they built a stalled machine, a mppt may be good option if they have no skills of their own.
Lastly, I can easily build a solution if I needed to (and I don't), and DaveB seems to have done a fair effort in that direction already. It would not take much to adapt his design to a full fledged mppt. If you read the capacitor discussion on the backshed, it would seem that an electronic solution is not the only answer to the problem.... and that kind of money spent on caps would produce a better more stable device anyway.
Were not all helpless, and there are a lot of solutions that will work for a lot of different situations, your experience is just yours.... not mine.
Interestingly a lot of folk who live off grid here, don't strike me as renewable energy gurus just because they do live off grid and have since the fifties.
When the smoke gets out (and it will.... I note your safety triac will help with surge, but the ripple will kill the caps eventually), no matter how good their backup is, once Australia Post gets involved, rubbing sticks together will be a better way to get power while waiting.
And Volvo, I urge you to read Flux's matching the load. If you design for the right part of the curve, you get a fair bit of the curve to play with. If you want good performance with minimal electronics, then higher cutin with cap doubling as per Gwatpe (backshed) will give you your low and mid and high..... (or a booster.....but seems less good than a good cap design)
GwatPe has managed to get as near as to perfect, the cubic relationships between his mill and his batteries .... just with caps, and with very very good monitoring software to back up his claims.
So I don't share your all your views, and feel there is plenty of cause for the home mill builder to not despair and think he can only succeed with the help of your mppt solution..
Its all in the design..... and there are plenty of options around.
...........oztules
