Author Topic: What would happen if . . . .  (Read 3145 times)
Titantornado
« on: November 07, 2011, 04:23:08 PM »
OK, here's what I'm thinking.   I have 12 Sharp NT-175 panels that I would like to temporarily use for supplemental heating for a travel trailer.
Panel specs are:
175 W
35.4 Vpmax
44.4 Voc
What would happen if I were to connect two strings of six directly to a 220v 2000w baseboard heater?  Seems the panel array output and heater input would be a very close match. (2100w @ 212v, and I suspect voltage would rise a bit if the heater draws under 2100 watts)
My brain thinks this would work, but it's been known to err on occasion.  Opinions?
« Last Edit: November 07, 2011, 04:27:40 PM by Titantornado »
wpowokal
Re: What would happen if . . . .
« Reply #1 on: November 07, 2011, 04:54:07 PM »
In series volts add but watts stay the same, so each series string will give you 6 X the individual panel volts but still only 175W.
allan
wdyasq
« Reply #2 on: November 07, 2011, 05:05:52 PM »
Amps would remain the same .....
A X V = W
rossw
« Reply #3 on: November 07, 2011, 05:10:57 PM »
175W with Vmp=35.4 = 4.94A.
In series, the CURRENT will remain the same.
6 * 35.4V * 4.94A = 1050 watts @ 212V
Two identical parallel strings would still be 212V, but 2100 watts.
Voltage is *slightly* less than the elements nominal voltage, so it'll take less current - panel output will increase slightly resulting in slightly more current, it'll settle somewhere close.
« Reply #4 on: November 07, 2011, 06:13:10 PM »
TitanT;
I would look at possibly the electronics of the baseboard heater.
See if you really need to have it at 220V. AND which type AC or DC. The instantaneous power may NOT be enough to get the heater heating, so to speak, since they are such a close match.
More than likely the heater will pull the panels down to voltage and dissipate the incoming power enough to just not work like you're possibly hoping.
IF they are Ni-Chrome based elements then I'm thinking there's enough electronics in there that you may be able to bypass? and go directly.
Since it is a heater even a MSW will work. Did this in the realm of 120VAC unit , oil filled heater when Natl Gas was shut off last winter due to leak at neighbor's house. Killed my standby Auto-batteries but worked 120Vac 2k watt inverter cheapo from HF.
Hope that helps address the heater portion.
mab
« Reply #5 on: November 07, 2011, 06:59:35 PM »
Not sure what a 'baseboard' heater is but if it's low temp resistive element then it should work.
I would think carefully about switching though - the AC switches on the heater won't like it if you try to disconnect DC at full load - Voc of 264v can produce quite a long arc. The inverter route suggested by Bruce might be safer.
mab
wpowokal
« Reply #6 on: November 07, 2011, 07:06:54 PM »
Ross and Ron please stop trying to spoil my fun :(
« Reply #7 on: November 07, 2011, 07:22:16 PM »
mab
You could use the switches to switch suitable relays at a lower voltage on the coils. Would need a source of volts correct  for the relay coils to do it but not too tough.
More than one way to defur a feline!
Titantornado
« Reply #8 on: November 07, 2011, 10:36:37 PM »
Hmmm, so mixed reviews.
For those who asked, an electric baseboard heater is simply a calrod type resistive heating element with aluminum fins fitted to it to increase convection air currents across it, no electronics.  I did think about using one with a built in, bi-metal thermostat, but as mentioned, those contacts would get cooked on DC.  Really, 2000 watts, which converts to roughly 6800 BTUs isn't enough to heat the trailer, so it could be left hard-wired right to the panels.
rossw
« Reply #9 on: November 07, 2011, 10:55:19 PM »
IE, exactly what I surmised you would have/do in my original reply to you.
If you're not switching it on and off, don't have arcing problems to deal with, don't have electronics to get upset, pumping whatever power you can harness directly into the heating elements should give you a reasonably good outcome with little to no maintenance and minimal losses.
Titantornado
« Reply #10 on: November 09, 2011, 06:25:35 AM »
Nice!   So I guess my brain was working on par.    I think I might give this a try.  It would save quite a bit of propane.
