Author Topic: HELP!! Generators control box had electrical fire!  (Read 2483 times)
XeonPony
  • Sanity is over rated!
« on: November 12, 2011, 10:13:02 PM »
The Autostart and switch over system had an electrical fire, the circuites are intact and undamaged as are the relays, it was just the wiring bundle as it entered the box have burned through!
I need a schematic to rewire it as all wires are the same color and the idents got  fried! It is an inline 4 cylinder deisel.
Thanks for any help need the schematic for the consol box for the autostart wire hook ups.
Pannel & Alt :  Simpson Maxwell
Model number: GCPX / CDS
Serial Number: 12731
Altenator:
Unit Modle: 16.5 KS-BIF-18E
Ph: 1
Hz: 60
Kw (Kva) 16.5 (16.5)
V: 120/240
RPM: 1800
Engine:
Modle number:  V1902BG
Serial Number: T22711
Genset Modle: BCI184F16
Serial Number: C042254/14
XeonPony
Re: HELP!! Generators control box had electrical fire!
« Reply #1 on: December 01, 2011, 09:02:44 PM »
Ok I manualy was able to get the engine running after replacing starter and fuel pump.
Auto circuite is still dead but at least I can start it manualy via the raw wires
So just figured I'd give an update.
