I have some advice, take it for what it's worth. Let your machine run and observe it for quite some time in all conditions before deciding if you want to make any changes. Turbulent, gusty winds will not give you a good idea of your furling and output performance. Straight line, constant wind varying in windspeed and being able to monitor this speed accurately while observing your machines performance and furling etc. is the only confident way to base your decisions on any design changes. I have made the mistake, a flopping around partially furling tail does not necessarily mean early furling. If you have not observed the straight on consistant winds of 25-35+ MPH I would be very hesitant to make any changes before hand. If your 1200 watts is some where around 20 MPH you may be much closer to being on the max edge than you think, above 20 MPH things happen very, very fast and tweaking your furling very little can push you over 3 KW in a big hurry. Enjoy a conservative machine instead of as Chris would say a "buzz bomb" high speed machine always waiting to blow. Stay safe, Dave B.
