There are also several threads about folks building really good smaller machines from servo motors, those will actually make some decent power.
like a 50lb after brake removed servo like mine pushing 800w at times.
maybe we should take a step back... would you be happy with peaks of 100w, and sometimes see 50-70w and mostly see 0-30w?
IF that's the case, then you're probably on the right track. 7' blades you were talking about are not going to be needed for 100w max. in fact the 5 footers will spin faster and probably do better, not to mention the 7 footers will most likely rip your tower down in the first decent storm.
it's all about what you want and your expectations. any PMA less than 20 lbs is going to have pretty minimal output. period. unless you live on the summit of mt rainier. trust me, it's REALLY windy up there!
i guess what it all boils down to are your expectations, and the money you spend to get there. you have already mentioned dissatisfaction at buying additional tower hardwear at lowes, and your tower is far from robust even for a 5 footer. and then you put a turbine on top that rarely give more than 50w.
most of us here are all about cheap watts. IE: make it, scrouge, re-use, make it stronger than it ever has to be, but with scrap steel, and find a PMA for cheap that really puts it out, and dig through yards for stuff, and take that old computer they're throwing out and pull some useful stuff out of it, and ordering stuff online, because i know i can get 4 turnbuckles for the price of one a lowes if i'm willing to wait a week for delivery... yea, all that kinda stuff.
so if this is just a large experiment for you and budget isn't an option to produce a mere 110w, then keep on keeping on.
if your looking to produce real power, and maybe be able to really use some of it, then it's time to get serious, and re-think your tower and the lightweight part of you system.
maybe even another pipe of identical size welded every 3' sistered to your original pipe? i dunno, even that doesn't sound all that strong.
have you atleast moved the upper guys to the point where there's just a foot or so of blade clearance? you can't have 8-10' of unsupported mast... major disaster waiting to happen!
just trying to help, and put things into perspective!
adam
