Author Topic: Piggott Blades simplification possible?  (Read 77878 times)
0 Members and 5 Guests are viewing this topic.
Janne
  • Country: fi
  • Turbiini
    • My image gallery
Re: Piggott Blades simplification possible?
« Reply #33 on: April 03, 2012, 02:13:21 PM »
The side faciong away is not touched at all as this is on the bottom of the wood piece over all the length(!!!)
Hi Max,
What I meant, is to first rough cut the trailing edge with a chainsaw (from the high point of the profile, to the trailing edge) to reduce the need for power planer time. But now thinking it again, the amount of wood removed from there is quite small, so it might not make much sense to put the chainsaw to work in there.
For the side facing the wind, I'll have to go with the chainsaw, as I don't have a band saw big enough to cut it :)
For some reason the ripping chain does not sound too good, as the goal is to make a cut as clean as possible, to reduce the need for sanding.
Menelaos
  • Country: de
« Reply #34 on: April 03, 2012, 02:21:03 PM »
there really is only little material to take off from the lee-side, nearly nothing up to half way from the root of the blade...at least for the trailling edge...its really not worth it making this with a chainsaw. If you want it quicker, I would use the power planer but for my small 10 foot blade set I used a manual planer for that and the did the fine tuning with the power sander and later by hand.
This whole method of course only works out accurately if the Lee seide of the untached wood is absolutely even. For this I do have a surface planing machnineso that I can get it nice and even and the right thickness...
Menelaos
  • Country: de
« Reply #35 on: April 04, 2012, 02:45:00 PM »
Ok...I did make a video but it still needs to be cut and in some parts I had my hand on the microphone so that needs fix as well... After easter I will post it here and I hope you will like it...
Max
Menelaos
  • Country: de
« Reply #36 on: April 05, 2012, 11:14:39 PM »
Well, here is the video:
http://www.youtube.com/watch?v=tK-83KUKC8w&feature=youtu.be
It didn't turn out well and I will make a new one somewhen but for now it' ok ;-)
Its hard to to stuff and explain things in a foreign language the same time, so please do not kill me for my english !
When my chainsaw arrives I will make a jig and see how that works out ...
Max
« Last Edit: April 06, 2012, 12:01:40 AM by Menelaos »
gizmo
    • The Back Shed
« Reply #37 on: April 05, 2012, 11:30:16 PM »
I got a "This video has been removed because it is too long. "
Glenn
Menelaos
  • Country: de
« Reply #38 on: April 05, 2012, 11:31:13 PM »
oh sh...I will see what I can do about that....took me 2 hours to upload it...
Menelaos
  • Country: de
« Reply #39 on: April 06, 2012, 12:02:25 AM »
Ok, I started a new upload and changed the link in my previous post, should work in about an hour.
That video is 27 minutes long so I had to do some activation on my account first to be able to get more than 15 minutes uploaded...
Max
« Last Edit: April 06, 2012, 12:05:01 AM by Menelaos »
gizmo
    • The Back Shed
« Reply #40 on: April 06, 2012, 02:45:20 AM »
I thinks its very good Max  :)
Thats a scary bandsaw you have there!
It should be fairly straight foward to modify Oz's chainsaw method to use your idea Max, and that would mean only one cut.
Well done.
Glenn
Menelaos
  • Country: de
« Reply #41 on: April 06, 2012, 02:56:59 AM »
Yeah, that band saw is a monster. It was built in 1922 and has a weight of 2 tons....equiped with a 5 KW motor and if you switsch from star to delta too early it will kick all the fuses in the workshop :-(
With a chain saw and only one cut needed this could be a good way of beating the time world record in blade carving ;-)
« Last Edit: April 06, 2012, 03:02:18 AM by Menelaos »
southpaw
« Reply #42 on: April 06, 2012, 09:38:38 AM »
If a picture is worth a thousand words, this video is worth a million.
Good job, Thanks for posting it.
It makes blade carving seem much more possible for someone who was always hesitant to try.
jlt
« Reply #43 on: April 06, 2012, 10:40:40 AM »
  That's a great video.
     After watching it I got a brain fart, how about mounting a electric chain saw from underneath a table with blade sticking straight up. Sort of a redneck   band saw.
                                       JLT
JeffD
« Reply #44 on: April 06, 2012, 12:45:39 PM »
I've been carving blades using Hugh's method for about five years now so I was sceptical about how much easier and quicker this method is.  After watching the video I built a set of 3 blades this morning for a new 1m turbine I'm working on and wow, I'm a convert now.  I had been using a band saw for rough cutting my blades before but some cuts were tricky and really slowed down the process.  With your method the cutting process is now a lot easier and definitely quicker.
The lay of the blade is different to what I am use to so looks strange.  Will be another two weeks before I get this turbine up in the air and connected to the data logger to see how well the new blades perform.
Thanks for sharing your work and making the video.  I agree too that in the video you did a great job at explaining your method, no need to redo it.
Menelaos
  • Country: de
« Reply #45 on: April 06, 2012, 04:44:22 PM »
Thanks!
@ jlt:
That came to my mind as well but I guess that it will be quite difficult to handle as the chainsaw blade is really thick...but I didn't try it. I feel that if you want to get it accurate with a chain saw, using a jig is the best way of doing it as you have to points to guide the chain saw blade with some preassure...
The advantage on teh other side would be that building an "band saw" this way would be really cheap if you consider that you then can cur really thick blocks of would where cheap band saws can only do a few centimeters.
Another problem might be that the chain saw blade is really wide. This might be good for straight cuts but for getting angles it will be difficult. Furthermore with my method you will have to cut "up hill". What will then happen with the back side of the chainsaw blade, will it damage the wood that is left? I cannot tell as I have never used a chain saw in my life befor...  ::)
@ Jeff:
The blades will perform the same if you used the same angles and dimensions. Basically nothing changes to the airfoil or the stations....but anyway I did not expect someone would try it only a few hours after I put the video online and I am happy that you can confirm that it makes things easier :-)
Would be nice if you can post your results here!
Max
« Last Edit: April 06, 2012, 04:58:15 PM by Menelaos »
fabricator
  • My smoke got out again
« Reply #46 on: April 06, 2012, 07:06:22 PM »
I've spent a lot of time running a chain saw, the chainsaw/bandsaw would scare the F out of me, that would be an imminent castastrophic injury waiting to happen.
"Here hold my beer and watch me saw my arm off"
Watt
« Reply #47 on: April 06, 2012, 09:55:55 PM »
Menelaos, very nicely done and great video.  Thank you for you for your time.
Menelaos
  • Country: de
« Reply #48 on: April 07, 2012, 03:12:26 PM »
this discussion bord is all about sharing, ricght? ;-)
« Reply #49 on: April 07, 2012, 05:14:30 PM »
Absolutely right.
Menelaos
  • Country: de
« Reply #50 on: April 08, 2012, 07:08:44 PM »
it would actually be nice to hear how Hugh feels about that...
Watt
« Reply #51 on: April 08, 2012, 07:23:30 PM »
You may send him a pm with a link to this thread.  His user name here is scoraigwind
fabricator
« Reply #52 on: April 08, 2012, 08:50:07 PM »
Max, if you put these blades on a machine and it performs as expected, to put it bluntly with NO disrespect intended what does it matter what Hugh thinks?
FAB , I knew what you meant, but wasn't where I could fix it , fat fingers & small keyboard on phone :(
« Last Edit: April 09, 2012, 11:37:49 AM by Bruce S »
Menelaos
  • Country: de
« Reply #53 on: April 09, 2012, 10:41:14 AM »
just because I want to let him know as my idea developed from the plans in his book. He gives those workshops around europe and he writes those books on how to do stuff and I am sure he does not mind knowing about different ways of approach and mybe adapting it...
I am not sure if I got the meaning of that last sentence right...but to make it clear: this has nothing to do with disrespect. I do not want to walk around telling everybody how great my style of doing it is and how much all the other methods suck...
I just want to share the solutions that I have found to make things the way that I feel is a lot more easy and accurate and as Hugh has a lot of experience in blade carving and I like what he is doing over there, I feel he should be updated on things like this...
Max
« Last Edit: April 09, 2012, 10:43:22 AM by Menelaos »
fabricator
« Reply #54 on: April 09, 2012, 11:08:06 AM »
Fair enough.
fabricator
« Reply #55 on: April 09, 2012, 11:09:53 AM »
Had to change that a little, I forgot the "NO"
Menelaos
  • Country: de
« Reply #56 on: April 12, 2012, 11:30:02 AM »
ok, that makes sense now :-)
Menelaos
  • Country: de
« Reply #57 on: April 19, 2012, 02:36:54 PM »
hi guys,
It is probably a little early...but has anybody already tried to copy my approach of making blades?...it would be nice to get feedback on the procedure and of course on the results :-)
Max
scoraigwind
    • www.scoraigwind.co.uk
« Reply #58 on: May 20, 2012, 03:45:31 AM »
Hi guys,
Sorry for not replying sooner, but I don't get around to looking at this board very often.  I am kept very busy with emails.  Next time maybe somebody could send me an email and I will check in.
I agree that this is a simpler way to do it.  Dan also uses this method I believe.  He doesn't seem to read this board much either...
I do have a reason why I do it the way I do and I am not sure it's a good enough reason but I will explain it anyway.  I like to make the airfoil from a rectangular section of wood where the back is parallel to the front.  That way I know that the thickest part at 30% is actually the thickest part.  If the back is angled, and the 30% line thickness is a certain value, then this cannot also be the thickest point on the back.  In my way of thinking it can only be the thickest point if it is also parallel to the front, windward face.  I don't like any sort of corner at the thickest point, it should just be the top of a very gradual curve and as such it must be parallel to the front face.
So that's my logic.  It seems to me that the main saving in the 'Menelaus' system is that you don't have to measure and mark so much.  In the end you do have to cut off the same amount of wood and you do have to make two finished faces.   I know that all sorts of shapes work well, and I have seen blade sections that look awful to me and fly OK.  I don't have any objection to people making blades in any way that works for them and I personally do make changes to my blade carving procedure so as to make life easier at times.  I will think about modifying my instructions to reduce the number of stages and the amount of measurements that need to be made.  I am not convinced it would save me much time as I am pretty quick at doing it my way but of course a simpler way is quicker to learn.
Thanks for sharing ideas!
Hugh
scoraigwind
« Reply #59 on: May 20, 2012, 03:42:17 PM »
OK now I have watched the video I have a couple of other comments.
Nice work!  It's a quick way to make the blades.  I wouldn't enjoy doing it that way very much, but I appreciate that the pleasure of using sharp tools without noise and dust is not everyone's priority.  The use of the bandsaw is very ingenious.  It seems to grunt a bit at times when the twist gets tight, but Max knows how to drive it.  He doesnt' seem to use a plane and hardly uses a drawknife but maybe he tried that already and found it too slow.
I do have some worries about the 'thickness'.  The thickness gets marked at the leading edge but then a reduced thickness gets marked at the trailing edge so there is a tapered shape where the back or 'lee' side is going to be a bit sloping relative to the windward or front side.  So you lose some thickness (especially at the inner end).  You also end up with an angled face at the 'thickest point" which as I pointed out in the last message is not going to be the thickest any more unless it is parallel to the front.
I am probably nitpicking here, but suggest you might want to add a bit of thickness if you want the blades to be as strong as I like to make them.  Other than that I can't fault the resultant shape.  What works for you is fine by me.  I put the video on my blog at http://scoraigwind.co.uk/2012/05/making-wooden-blades-with-max/.  Thanks again!
Menelaos
  • Country: de
« Reply #60 on: May 25, 2012, 06:04:21 AM »
Hi Hugh,
I didn't get a notice on the update on this topic...sorry for answering so late...
For the small blades I do not use a drawing knife except for the root section. For bigger blades I definitively do use both, drawing knife for the root section and roughing out the leading edge and manual plane for the lee side of the trailing edge. A power plane is a tool that just doesn't work for me, whatever I do with it, it will destroy everything but I have about 30 different manual planers to choose from ;-)
...call me mad... :-D
I have recently made a Set of Blades with 3m diameter using my method. I did make the blade thicker there, especially on the tip section where it is about 11 mm thick. The wood blank was 20x6 cm laminated wood which is an easy to get standard size over here and when you buy it, it is already plane on all 4 sides.
I do not quite get your argument about the highest point of the airfoil...
I did cut through one of my test blades to see the different sections....it all looks good.
I now have my blades drawn in a CAD program so I can choose exactly where the highest point of the airfoil has to be on the different sections. and I leave about 1mm of space to get a nice round shape when connecting leading and trailing edge an still have the right thickness.
I do not see any difference to your airfoil shape concerning that. With your way you get the 2 sides parallel, mark the 1/3 line and work down from that section. In my case that line is the highest point from the beginning on the bottom of the blank wood. In the end the angles and the shape of the airfoil are identical to yours. Of course it is not quite correct the way I did it in the video. The way I marked the 1/3 line there is not really correct. In my CAD program I now did measure that point from the windward side and corrected the distance that has to be taken on the Lee-side. This is probably what you meant and you were right with that referring to the video.
Also using your numbers for thickness and drop for my method does not exactly give the same results on the final airfoil shape. I adjusted for that for another test blade and it then worked out correctly. I now have kind of my own design.
If you like, I can post the dimensions for the marks on leading and trailing edge for my 3m diameter prop here. There everything is correct concerning the angles and the highest point of the airfoil.
In the end everybody has his own style of doing it. For me, this way of carving blades is by far faster.
I have now made stencils for marking all the lines and I do make all 3 blades the same time....step by step to increase accuracy and processing speed. This way I can make a complete set of 3 1.5 m blades in about 6-8 hours, depending on how many people come by to disturb me ;-)
ps. My nickname is menelaOs and not MenelaUs...its a little funny as a "Laus" in german language is that kind of bug that lives in peoples hair... :-D
Max
Also I now only use 3 Stations, one at the root, one in the middle and one for the tip, I feel that this is enough
  • Country: aq
  • Village idiot
« Reply #61 on: May 25, 2012, 09:04:18 AM »
Also I now only use 3 Stations, one at the root, one in the middle and one for the tip, I feel that this is enough"
Ditto!
.............oztules
scoraigwind
« Reply #62 on: May 27, 2012, 05:22:28 PM »
I haven't tried using only 3 stations so I can't say how accurate the job is like that, but you must have to keep the cuts pretty straight to make the blades come out all the same with so few stations.  I am probably too fussy with all the measurements and the stages of my method and I will look at simplifying it more in future.
I still don't see how you can mark the thickest point on a face that is not parallel to the windward side.  By definition the thickest point must be parallel to the other one.  If it's at an angle like you make it, then you need to remove more wood to get that point to be parallel, and then after that it is less thick.  But again, this it probably just my fussy attitude, and in practice the back is close to parallel in the outer part of the blade where it matters.
Frank S
« Reply #63 on: May 28, 2012, 09:41:14 AM »
 Hugh; after seeing his method and the way you do yours it reminds me of when Me and my BTN commander were building his twin engine 4 prop bi- plane. we got down to the props so we sought out a couple of German wood carver guys, this was back in the mid 70s  my COl. gave them his plans for the props. since the rear props were pushers they had a different pitch angle 1 guy did the front props while the other did the rears. It was like watching a carnival act  one guy was all MR. perfection in his measurements the other reminded me of an oilfield rough neck by the way he attacked the task for his measurements. But in the end both had a finesse  in the way they each finished polishing that would have made Charles Lindbergh proud.
 It will be a year or more before I get to the point of needing blades but I suspect that I will probably do the measuring of your method and the cutting modified from his done on a table saw used more like a CNC milling machine , by making a fixture to add a 3rd axis then drawing the blanks cross ways to the blade taking fine cuts while turning the blade about its longitudinal center line
Menelaos
  • Country: de
« Reply #64 on: May 29, 2012, 07:29:49 AM »
sounds interesting...but I cannot quite imagine your cutting process. Maybe you can make a drawing on your setup...?
Max
Frank S
« Reply #65 on: May 29, 2012, 09:24:07 AM »
Menelaos ; here is a simplified explanation.
 First off it means you need a table saw capable of holding 3 to 5 saw blades as if you were going to cut a mortise & tenon joint some call it a square dado cut
 next you need a sine bar table with straight non tapered bars longer than the blade mounted longitudinally  to the saw blades  a fixture would slide on the sine bars with the work piece held in place the fixture needs to be so that it may be rotated and at each end and with some vertical and lateral adjustment
 a 3rd sine bar mounted above the fixture would elevate & lower at 1 end  an arm from the fixture follows this to create the rotation or angle required to scarf out a profile.
 then the blade and fixture is slid back and forth just skimming the teeth of the saw blades.
 Basically the table saw becomes a big scarfing router. anyone who has ever had to use 1 to take the place of a wood lathe for making long tapered or shaped pieces would understand I am sure.
 It works just the opposite of a panagraph and router and is probably more work than a band saw or chain saw method
and a belt sander is still needed to finish off the surface.
 The guys that made the Col's props only had 2 power tools in their shop 1 was a belt driven table saw the other a drum sander the sander had the drum mounted vertically and it osolated up and down everything else was done by draw knife chisel & leather mallet or hand planes
