Author Topic: Burning Elm  (Read 7055 times)
klsmurf
Burning Elm
« on: March 23, 2012, 09:26:07 AM »
Hi all,
I have a HUGE elm tree at my house in town that has to come down. I hate to take any tree, but this is a hazard. It's 60 feet plus with multiple trunks, that would take out all my neighbors garages (depending which way it fell) if it fell. It's a great shade tree. but has to go.
I've checked on the web and found:
Elm is in the middle of the pack as far as BTU's / cu. ft. compared to other woods.
Elm is a tough wood to split.
If I were to use it, it would be used to heat a shop in an out building on the farm.
Anybody have any experience or knowledge of using elm as firewood?     Thanks
DanG
Re: Burning Elm
« Reply #1 on: March 23, 2012, 10:14:19 AM »
If the sap is already up, leaves budding out, then the best firewood opportunity is next winter - split while hard-frozen!
Re: Burning Elm
« Reply #2 on: March 23, 2012, 11:14:06 AM »
this last winter was only my second year burning wood in the shop
i had to split one piece of elm and i remember it was a pig
i have a hole tree cut up and ready for next year.
it's big dia.  i will rent a splitter.
Re: Burning Elm
« Reply #3 on: March 23, 2012, 02:25:29 PM »
Cut and burned elm for years. Take it down now so it can start drying and split towards fall. I always used a hydraulic splitter and never attempted splitting it by hand. Burns hot and long and makes an excellent firewood.
Isaiah
Re: Burning Elm
« Reply #4 on: March 23, 2012, 05:15:39 PM »
   If its a red elm  cut into logs and make lumber out of it !! They used to use it for runners on bob sleds  and stone boats etc will last a long time!
If it would not be suitable for lumber then cut in logs like you would  for lumber then take a 18'' small chain saw and cut a hole in the centre of the log as deep as you can one stick of 40% dynamite and mud the hole shut and ignite, and no one or two sticks wont blow out the neighbours windows
klsmurf
Re: Burning Elm
« Reply #5 on: March 23, 2012, 05:33:02 PM »
Thanks for the responses. I'll keep most of them in mind, no dynamite. I was told it was a Chinese Elm, but I'll have to do some checking on that. It's just starting to bud out now.
ThomasJ
Re: Burning Elm
« Reply #6 on: April 26, 2012, 05:51:29 PM »
Chinese elm is very fibrous and hard to split but it does burn decently once it has been allowed to dry. I would suggest that you cut it late in the fall after it has dropped it's leaves because these trees tend to hold a lot of water during the growing season and the sap really smells bad. After 20 years plus of working as an arborist, I learned to wear a particular set of clothes whenever I was working with chinese elms because the smell can be persistent especially when you are working with an older tree
governments should be afraid of their people, not the other way around
klsmurf
Re: Burning Elm
« Reply #7 on: April 26, 2012, 07:07:13 PM »
ThomasJ... Thanks for the info. It is a Chinese elm, and all leafed out now.  BTW welcome to the forum!
Kevin
ThomasJ
Re: Burning Elm
« Reply #8 on: April 26, 2012, 08:03:57 PM »
Thanks for the welcome  :)
