Author Topic: For Sale - 16' Axial Wind Turbine  (Read 2072 times)
Dave B
    • DCB Energy Systems
« on: May 04, 2012, 04:16:19 AM »
I built this 16' turbine nearly 7 years ago and have flown it in several configurations including high voltage water heating, 24 volt and 48 volt battery charging. I will include 4 different stators for conversions.
 It is dual 1/2" x 16" diameter rotors, 6 bolt hub, 40 (20x2) 1" x 2" x 3/4" N42 neos 3 phase 15 coil stators. Ash 222 profile blades, glass over foam nose cone, auto and manual  furling with hydraulic damping, commercial grade slip rings and brush assembly, ball bearing yaw and grease fittings. Tail is aluminum and the main assembly and tail boom is steel.
 I have run this machine up to 3 KW in each configuration no problem but that is upwards of 300+ rpm. Tweaking the furling and airgap in it's current 48 volt battery configuration I have it set very conservative at approx. 1500 watts max slightly over 200 rpm approx. 20 mph. There is a lot of room to play but the 222 blades are very fickle where they run best without stalling or overspeed.
 I have faithfully maintained this machine and last Spring I did a complete tear down, inspection and maintenance on it. I plan a different machine in the near future and with only the one tower the top needs to be vacant when it's completed ready to install.
 If the moderators allow the link you can see it run here at www.dcbenergy.com  I am located in Western NY near Jamestown in Chautauqua County. Come see it running, we'll lower it down and I'll help you dis-assemble it and pack it up with you. Advice is free, turbine, tower stub and 4 stators is $3,000.00
 Reply here on the board or email   bruggelog (at) netsync (dot) net
  Dave B.    www.dcbenergy.com
DCB Energy Systems
http://dcbenergy.com/
