Doc wattson question: maybe a few....
I have zero data of the storm on the doc.
I also hve zero data of the storm on my weather monitor. (Forgot to feed it batteries- duh)
I thoaght maybe the doc was not solidly wired,
so last evening I wired it an made sure all the contacts where solid.
Once done we had some solid wind come through...
I stood there and watched the doc live as the blades easily hit 200 rpm
Nothing...
not even a .1 volt on the doc.
It shows the info from the batteries but nothing from the turbine.
Is this because the turbines rectifier is directly tied to the battery
with the doc similary tied in but bridged?
If so because the doc is also under the same resistance
will the doc not display a single milivolt until cut in?
I don't understand what is wrong here?
I can take a picture of my set up if you guys think it may be do to stupid circuit work.
