@ Fab;
Sorry all, I have family out near our hosts and with the fire going out of control in CO!! I was otherwise occupied this past weekend.
FAB;
Let me see if I can help defuse this issue. thanks for looking out for the forum!! please send me an email next time!! or do the whole report to admin button.
@Mike.
Fab is reacting to stuff from the recent past, where, more than one "person" has posted here with UN-realistic numbers, then gone-on to other places even ebay, without so much as a thanks or note.
Even Windstuff Ed's blade profile was being out-right copied by Pacific--- without even a nod to ALL his work.
I looked at the ebay posting. Even posting the links are normally a no no unless you're up over 50 posts, and I'm not sure where the other Admin/GM are with killing those ebay alibaba links in your posting are. I can understand the DANS a bit busy what with a fire heading towards them and all!
@ALL
OKAY, now the numbers you currently have up show 12V 45A that's 540watts.
Those numbers without wind speed, RPM, load, and actual testing numbers like Jerry use to put up; make it look like other's who are normally out to just get money.
I see that you've taken the chart down, that's good, even I (not a big windmill number guy) would've been able to tear it apart.
Best thing to do is to put up wind speed with real world output.
That will make your ebay posting stand out from the rest of the crowd.
BTW: Fab is a 'mill numbers guy so I can understand where his temper is stemming from AND he holds the ALL time banned record in one year, one month,etc.
I will ask that you NOT post any more links to ebay or alibaba, I will be forced to remove them.
I should remove the others, but we'll see.
Your machining skills are great, but try not to fall into the same hole bunches of other do by posting copied charts.
