I got lots of land to test but I live two hundred miles due west of you, the problem I see is the problem Frans was getting at, you may have double row bearings but they are in the same block and that block is held on by two bolts, that is going to be one of your first points of failure.
The bearing blocks should be separated by some distance each with it's own beefy bolts.
