Author Topic: 0.5 hp pmdc as a generator  (Read 1894 times)
anuraag.bhatt
  • Country: in
« on: July 07, 2012, 08:24:01 AM »
hey friends, i am kinda in a confusion,
i have a 0.5 hp, 1500 rpm, 12nm, pmdc that operates at 48 volt. i want to use the motor as both a motor and a generator....
can you people tell me if that is possible and if yes what things i should take care of....
Re: 0.5 hp pmdc as a generator
« Reply #1 on: July 07, 2012, 10:18:49 AM »
Spin it up on a cordess drill . They work in that range and measure the out put.
tanner0441
« Reply #2 on: July 07, 2012, 05:25:42 PM »
Hi
What voltage do you want to generate? 12 V would need around 400 RPM not too bad but 24V or more the revs are way too high.
Brian.
anuraag.bhatt
  • Country: in
« Reply #3 on: July 07, 2012, 06:32:21 PM »
i am flexible with the voltage...suggest a plausible solution with the voltage of your consideration...
