Author Topic: Project Porn  (Read 20981 times)
kitestrings
Re: Project Porn
« Reply #66 on: October 05, 2012, 01:04:53 PM »
To avoid the coupling issue I assume.  I'd understood that coupling was more of an issue as the distance increased along an axis say.  In the case of an axial thing are pretty close together.  Still a concern though, huh?  We still can do it separately, so I'm glad to have the input.
Now in your case the magnet rotor speed is also alot higher.  This is also a factor?  In our case we're direct-drive.
~ks
fabricator
  • My smoke got out again
Re: Project Porn
« Reply #67 on: October 05, 2012, 06:30:47 PM »
Yeah it's more of an issue at higher speeds but it can still cause you to pull your hair out when you go to balance the entire rotor with the blades on even on a direct drive machine.
kitestrings
Re: Project Porn
« Reply #68 on: October 06, 2012, 01:54:54 PM »
The hair has been gone a long time (unless we count unwanted areas), but your point is taken.
~ks
