Author Topic: FS: 6'8" (2 meter) blade set with hub  (Read 1807 times)
« on: December 29, 2012, 04:17:13 PM »
Well I checked with the county, applied for an experimental variance and they shot me down. All wind has to be UL approved on a tower that was designed for that particular turbine. So I am putting this rotor and hub up for sale and going back to a VAWT (lawn art!) project. Windmax fiberglass blade and hub set, 6'8" diameter. Hub is drilled for 1/2 inch shaft but has enough material to be bored out for a larger shaft. Blades have been sanded and a coat of primer and paint applied, needs to be wet sanded to get some runs out of the paint (My spray can skills are not good!). $75 + actual shipping (I expect around $20-40 because it will be a large box).
Re: FS: 6'8" (2 meter) blade set with hub
« Reply #1 on: January 01, 2013, 03:44:05 PM »
Open to offers too...
birdhouse
  • Portland, OR USA
« Reply #2 on: January 01, 2013, 05:38:44 PM »
are these the same brand of blades that chris o used to run?
olson??  you around?
i might be interested in running them on my mill as a theoretical...
adam
ChrisOlson
« Reply #3 on: January 01, 2013, 06:51:28 PM »
No, they're not.  The ones shown in the photo are WindMax blades.
Chris
