Author Topic: Are these batteries worth anything?  (Read 1983 times)
gww
« on: March 19, 2013, 06:00:01 PM »
Three year old batteries.  What would the 8 hour rate be at 20 hours?
  Guy says they are 20 year batteries.  Is this in float and not being discharged as the spec sheet shows 1000 cycles?
   RE charging good enough for them?
Are they better then sams club batteries?
Re: Alcad 2v 120ah batteries
Here's the Data sheet, the 120Amphours appears to be an 8 hour rate.
Just curious
gww
Oh well, the data sheet didn't show up as a link.
« Last Edit: March 19, 2013, 06:04:46 PM by gww »
XeonPony
  • Sanity is over rated!
Re: Are these batteries worth anything?
« Reply #1 on: March 20, 2013, 02:15:34 PM »
they'd probably be around 140 or so AH at a 20h rate, the rate just tells us they are really good at pushing the juice out, and an 8h rate isn't even all that great, in example the us2200 series golfe cart battery is 150Ah at a 5h rate, or 232Ah at a 20r at the 5h rate it can push 70a
gww
« Reply #2 on: March 20, 2013, 03:16:52 PM »
XeonPony
gww
