Author Topic: Will this work?  (Read 1803 times)
jab
Will this work?
« on: May 02, 2013, 07:24:57 AM »
Long time lurker, first post.   I do appreciate the info and knowledge on this site.
I have a generator that was purchased at an auction.   The gas motor that drove it was junk and is long gone.   My question is, would it make a wind generator?   I realize I would have to gear it up, but could never make 3600 RPM's   Would I be wasting my time?
Specs following:
Groban Supply Co.
Model =1010
RPM = 3600
Phase =1
Cycles = 60
PF = 1
AC Volts = 115
Amps = 8.7
Watts = 1000
KW = 1
Thanks in advance
Jim
Re: Will this work?
« Reply #1 on: May 02, 2013, 12:19:50 PM »
No use for wind, the gearing is not viable and also it will likely only work over a very small speed range, especially if it is capacitor excited.
jab
Re: Will this work?
« Reply #2 on: May 03, 2013, 10:40:48 AM »
Thank you Flux for your reply.   I was afraid that the answer would be something like you stated, but I wouldn't know unless I asked.   Thank you very much
Jim
