Author Topic: DIY Air resistive loads?  (Read 28831 times)
Re: DIY Air resistive loads?
« Reply #33 on: January 25, 2014, 01:23:14 AM »
the morningStar controller makes a lot of noise in dump mode.......i think its the nature of the beast....hard on/off fets
they have 6 ( at least ) big transorbs on the cct board .....it doesent like transient spikes from inductance in the load .....seems to hate them with a vengeance....
ahahaha.. ok there's the key right there..
the transorbs on the board are there to absorb the energy dumped into the mosfet, because they are cheaper than capacitors.
i can see its going to be a pain to figure out.. is the noise from the Di/Dt on the input, or the output of the pwm converter?
also, is there a diode, or does it have transorbs across the dump load (but no diode)?
niall2
  • Country: lt
« Reply #34 on: January 25, 2014, 01:50:56 AM »
" the transorbs on the board are there to absorb the energy dumped into the mosfet"
i,ve no idea joestue  :)......but i doubt it ....the transorbs would be a last resort ?...
arent transorbs just a fancy zener diode anyway ?
niall2
  • Country: lt
« Reply #35 on: January 25, 2014, 02:27:45 AM »
sorry ...thinking about it a bit more , yes the transorbs would soak up the damaging spikes....
i seen one controller burnt out , covered in soot and talked to a tech in morningstar ....he said clean up the board  , take out the fused transorb and re boot the controller
it worked fine ...5 transorbs left  :)
Vortechs
  • Country: ie
  • Smartdrive Micro-hydro & 300W of Solar Panels.
« Reply #36 on: January 25, 2014, 07:14:03 AM »
Thanks Joestue, you seem to know what you're talking about, unfortunately I dont,,, it's all a bit too technical for me. I'm the original poster of this thread. I have a Trace C40 controller using a Ohmrite
PFE5K1R00E 1ohm power resistor. I'm dumping about 500w into it at 28V. The noise was about the level of the average person talking, so I removed the ceramic core from the resistor and that made it quieter but now it's like having bad tinnitus all the time, a very high frequency noise, I've put a small fan blowing air over the resistor core to try and hide the high pitch noise but it doesn't help much.
I'm almost at the point of giving up on air resistive loads, I dont want to heat water so I'm now thinking about converting an oil filled radiator to a 24v immersion heater, any reason you can see that that wont work or be quiet for me?
OperaHouse
« Reply #37 on: January 25, 2014, 09:22:15 AM »
To put it simply, an inductor resists any change in current.  Whether it is at 0A or 10A, it wants to stay at that current.
When the dump FET turns on the inductor resists the increase in current till the magnetic core saturates.  If the inductor
is at 10A when the dump FET turns off, The inductor will generate whatever voltage is necessary to continue that 10A current
flow till the magnetic field collapses.  The theoretical voltage is infinite, the practical voltage is large enough.  For that
reason suppression devices are included.  A mov, zener, etc is included to protect the FET.  The clamp voltage must be above any
normal operating voltage the dump controller will ever see.
The problem is that these devices, even a half dozen of them in parallel, are designed for occasional transients and not continuous
duty into an inductive load.  Remember the power dissipated is a function of the volts across the device.  This is why a "free
wheeling diode" should be used since the voltage across it will e less than a volt.  And the diode needs to be fast, not a general
power supply diode.  Diodes take time to turn on and turn off.  Durring that time the voltage accross the diode will be higher and it
will generate more heat.  If this is just once and a while it isn't an issue.  If it is continuous, the power dissipated in the diode
can be several times what you expected.
« Reply #38 on: January 26, 2014, 05:26:30 AM »
@ Vortechs
I would certainly install it inside an oil radiator or something.
There are a few options to reduce the noise.
1) install capacitors across the battery supply cables, as close to the dump load as you can.
1a) do not be surprised if they explode
1b) if they get warm, install more of them.
2) After installing capacitors, increase or decrease the frequency. you might be exciting some mechanical resonance.
2a) I am not sure if this is possible with a C40? someone who has one can verify?
3) Verify if there is a catch diode inside the dump load. verify that it can handle the same current as the dump load. if there is no heatsink, install another diode. the 30 amp diodes found in computer power supplies will work great. it appears there is room inside the C40 (there should be one already)
3a) install as much inductance in series with the dump load as you can get. for the current you're dealing with three microwave oven primaries on the same core configured in parallel will be sufficient (for 120 volt systems, do you live in 220 volt country?) set the core gap to 1-3mm.
4) After adding much inductance to the dump load, install a few single digit uF capacitors across the dump load. non electrolytic only, look for the plastic film capacitors. they need to be rated for at least twice the battery voltage.
niall2
  • Country: lt
« Reply #39 on: January 26, 2014, 10:26:51 AM »
Vortechs  ...heres a 48v 900w element in a oil storage heater.....i dont hear any "buzz" from it , but lots from the controller beside it ...
one problem is these elements are fairly short (about 10 inchs ) so your really only utilizing half the radiator....theres usually a bung in the top of the heater thats the same thread as the element bung at the bottom , so the 48v volt element was put in on the top and the heater turned upside down ....
getting a thread adapter is the tricky bit (depending on the thread size of the heater)
7893-0
niall2
  • Country: lt
« Reply #40 on: January 26, 2014, 09:24:05 PM »
"also, is there a diode, or does it have transorbs across the dump load (but no diode)?"
i,m not really sure Joestue.....the fused transorb was one of a set of 3 in parallel directly over  +/ground.....kind of like fuses
there may be others over the source/drains of the mosfets ? ...maybe
"solar converter" in Canada make a pwm direct heating controller that seems to make no noise at all...
Vortechs
  • Country: ie
« Reply #41 on: January 27, 2014, 03:22:17 PM »
There's no diode across the power resistor dump load, this is the type I have:
http://www.ebay.com/itm/OHMITE-PFE5K1R00E-Wirewound-Resistors-Chassis-Mount-1-Ohm-1089-WATTS-2-PCS-/300888671916?pt=LH_DefaultDomain_0&hash=item460e5cc6ac
As far as I'm aware you cant adjust the frequency on the C40 controller, but I'm no expert.
I've bought a 24V 600W water heating element and acquired an old Delonghi 2KW oil filled radiator, it has a 1.5" threaded element hole in the bottom and the same size bung hole in the top. The new element is the same length as the old 220v one but has 1.25" thread, so I'm going to need a bushing reducer to make it fit. The heater has no thermostat so must be capable of dissipating 2KW continuously so the 500W should hopefully be no problem for it.
I'm glad to see someone else has successfully converted one of these before, I'll let you know how it goes...
« Reply #42 on: January 27, 2014, 05:44:42 PM »
well there should be a diode internally to the C40 but I can't find where they would put it.
sure looks like some kind of funky device attached to the heatsink, maybe they heatsinked the MOVs?
in any case externally the diode would be connected across the dump load.
as i mentioned the 30 amp 45 volt diode common to most ATX computer powersupplies will be more than sufficient, just don't connect it backwards and short out the dump load.
Vortechs
  • Country: ie
« Reply #43 on: January 30, 2014, 02:48:52 PM »
The 24V 600W water heating element arrived today so I put it in the old Delonghi oil filled radiator I found, connected it up to the controller, and ,,,,,,,  silence,  :)
I took temperature readings of the radiator every half hour for the first few hours, highest it went was 68*C / 154*F mostly sat between 50-60*C / 122-140*F
Vortechs
  • Country: ie
« Reply #44 on: January 31, 2014, 03:03:04 PM »
After a whole night of full load the rad temp was 187*F / 86*C :)
niall2
  • Country: lt
« Reply #45 on: January 31, 2014, 03:42:28 PM »
that was quick ....the long element seems much better than mine
twins then ....
« Reply #46 on: February 01, 2014, 11:25:05 PM »
That's excellent.
What a simple and elegant solution to the problem.
XeonPony
  • Sanity is over rated!
« Reply #47 on: February 02, 2014, 10:28:26 AM »
and very functional too man that must be great for winter heating!
Vortechs
  • Country: ie
« Reply #48 on: February 02, 2014, 02:27:08 PM »
It's brilliant for making use of the overnight power, you wake up to a warm house  ;D Surprised more people aren't using them.
XeonPony
« Reply #49 on: February 03, 2014, 07:17:53 AM »
I used a 500w base bord heater bolted under the beds head board, I ran a 230v AC turbine and the heater and some lights where my balast load, now I am sadly grid connected again as I moved tot he praries and no hills here for water, so need to build a wind genny and a bigger array.
Vortechs
  • Country: ie
« Reply #50 on: January 07, 2017, 02:21:03 PM »
Three years on the oil filled radiator with a 600W element as dump load is still working perfectly. I did have one issue with it so I just wanted to add this update for anyone else thinking of doing the same.
After the first few months one of the cables started over heating and melted, so I bought some very heavy duty 6mm speaker cable and made up a heat-sink / low resistance connector, which solved the problem and has been perfect ever since.
It's made out of 10mm copper pipe. The cable was striped and inserted into the pipe before it was flattened and drilled. :)
« Reply #51 on: January 07, 2017, 07:27:36 PM »
Happy new year!
Comfort and warmth, indeed :)
« Reply #52 on: January 09, 2017, 09:10:21 AM »
It's great to see updates from the older posts too.
Congrats on the uses and thanks for the update!!
plasmahunt3r
« Reply #53 on: January 17, 2017, 11:35:47 PM »
I know this is not exactly what the topic requested, but why not use MOSFET's as the Dump Load Resistors.  They are cheaper.  You can get a couple of 300W MOSFETs for around $5.  They would need to be mounted on heat sinks.  The bigger the heat sink, the better.
This seems to be better and simpler than these Frankenstein setups.
I drew up a circuit to show what I mean.
« Reply #54 on: January 18, 2017, 12:35:04 AM »
i actually used them as resistors once.
a 22mOhm mosfet is cheaper than a 22mOhm resistor in the same TO-220 heatsinkable package. the application i needed did not care about thermal coefficient, which as you know for silicon varies by an order of magnitude more than resistive heating wire.
anyhow, a zener wired from drain to gate turns them on. its up to the fet to hold down the fort at this point.
of course, negative, or positive feedback can be arranged.
Warpspeed
« Reply #55 on: January 18, 2017, 01:42:52 AM »
Don't forget about aluminium clad resistors, available from e-bay.
The Chinese ones are not now that expensive, and available rated to several hundred watts.
Main advantage is you can get pretty close to any resistance value you need, or can get even closer with series or parallel combinations.
They will need to be bolted to a suitably large flat metal plate to reduce the temperature rise, and avoid hot smells.  But its a very neat, civilized, and reliable solution.
