Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Wind
From aluminum tube to blades.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: From aluminum tube to blades. (Read 2487 times)
Yianie123.
Full Member
on:
December 11, 2014, 08:11:52 PM »
Does anyone have any experience making large aluminum blades from an aluminum thin wall pipe? Please share your experiences and photos. Thank you..
Logged
SuperHero Member
Re: From aluminum tube to blades.
Reply #1 on:
December 11, 2014, 10:17:51 PM »
Aluminum will stress fracture. Even aircraft aluminum alloyed with magnesium has definite flex lifecycle. Laminated wood is more difficult to fabricate but with proper care will last years and can be shaped easily.
What length blades do you want to make and what is the power output of the mill? What is the climate [freezing/snow/gale winds?].
Logged
Yianie123.
Full Member
Reply #2 on:
December 12, 2014, 06:44:06 AM »
I live 50 miles east of Chicago, in the snow belt. I am looking at an 8ft diameter find turbine.
Logged
MattM
Hero Member
Country:
Reply #3 on:
December 12, 2014, 07:32:05 AM »
You can always experiment although it's more than likely not to survive long if it's thin enough to flex. The fatigue basically comes from the mechanical stresses. The failure point from my experience with sheet metal would point to the attachment point. Tubes are generally extruded so that material tends to be more stiff and can be brittle. Ymmv
Logged
Yianie123.
Full Member
Reply #4 on:
December 12, 2014, 12:41:52 PM »
I am looking at using 8 inch diameter aluminum tube, 1/8 inch thick, approximatly 42 inch long.
Logged
SuperHero Member
Reply #5 on:
December 12, 2014, 03:57:48 PM »
Aluminum expands and contracts a lot with temperature changes, that's one of the reasons it is not used for inside wiring. Buried pipe isn't subject to temperature extremes and aluminum has good corrosion resistance.
If you were going to cast a blade of aluminum, Mercalloy 368 would be the choice. Low iron for stress fracture resistance and no need to anodize.
There are titanium-aluminum alloys available in tube form for making race cars, off-road vehicles and moto-cross bike frames.
https://www.irvansmith.com/scart/5712-aluminum-truss-bar-titanium-series-p-1281.html
Not very expensive. You aren't going to drill into or hammer that flat without some effort, though.
Logged
kitestrings
Hero Member
Reply #6 on:
December 13, 2014, 02:49:28 PM »
you might also check to see what phillm has done on the Back Shed. He's been doing AL blades for quite some time. Personally I'm not a big fan of AL blades, but might be okay for something this size. ~ks
Logged
Print
Pages: [
1
Go Up
« previous
next »
Wind
