Author Topic: Wind Blade Angle  (Read 2281 times)
Yianie123.
Wind Blade Angle
« on: December 14, 2014, 09:57:34 PM »
I am trying to figure out wind blade design.  My calculations indicate a tilt back at about 11 degrees at the fat end and 3 degrees at the tip.  Does anyone know better?
kitestrings
Re: Wind Blade Angle
« Reply #1 on: December 15, 2014, 12:40:40 PM »
What diameter and TSR are you planning?  IIRC you said it was 8' diameter.  "Fat end" is relative, but it doesn't sound like enough.
Plugging a 2.44m prop into Alton's calculator, with a TSR of 7 I get:
Station   Station Radius   Blade Angle In Degrees
1   0.12   40.1
2   0.24   21.8
3   0.37   13.4
4   0.49   9.3
5   0.61   6.8
6   0.73   5
7   0.85   3.8
8   0.98   2.8
9   1.1   2
10   1.22   1.4
Yianie123.
« Reply #2 on: December 15, 2014, 01:58:09 PM »
I am planning on an 8ft diameter windturbine.  I was basing my caculations on carving information and math.  Can you please send me any websites that explaln you email a little better.  Thank you,
Yianie123.
« Reply #3 on: December 15, 2014, 07:59:45 PM »
I found Alton's calculator.  Is there a website on a diagram of some of the variable define?
gww
« Reply #4 on: December 15, 2014, 09:16:29 PM »
This contains a great blade design and hughs book gives you the turbine plans that are most up to date.
http://scoraigwind.com/pirate%20oldies/Hugh%20Piggott%20Axial-flow%20PMG%20wind%20turbine%20May%202003.pdf
Hughs web site has stuff also.
Good luck
gww
Yianie123.
« Reply #5 on: December 15, 2014, 10:34:37 PM »
Thank you for the website.  It was extremely helpful.  I was wondering, do most still make the wedges in step 6 of MAKING THE BLADE.
« Reply #6 on: December 16, 2014, 03:44:02 AM »
If you like the look, add them. I really don't think you will see any performance difference, the centre of the blades contribute little to the power. I cant see the wedges adding any strength.
kitestrings
« Reply #7 on: December 16, 2014, 06:15:33 AM »
Here's another link you might find useful.  It has better description of the variables than Alton's.  It is part of a site by Ed Lenz:
http://www.windstuffnow.com/main/blade_design_help.htm
And, more from Hugh:
http://www.scoraigwind.com/download/windrotord.pdf
http://www.scoraigwind.com/wpNotes/bladeDesign.pdf
Hugh also has a blade design spreadsheet (similar to Alton's), in Excel.  If you go to his site, then follow the link to his "old site" you should find it.
If you're carving wood blades you might also find this helpful:
http://www.fieldlines.com/index.php/topic,127292.0.html
Probably more than you wanted, but fun reading.  Good luck.  ~ks
