Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Solar
Mixing Panels
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Mixing Panels (Read 1684 times)
kittysmitty
Jr. Member
Mixing Panels
on:
January 11, 2015, 07:56:47 AM »
My system is 12 volt with 2 100 watt panels. I looking at adding 3 135 watt panels. They would be in parallel feeding a single controller. Any issues? Downside? Thanks
Logged
Administrator
Super Hero Member Plus
Country:
Re: Mixing Panels
Reply #1 on:
January 11, 2015, 08:00:41 AM »
If their Mpp is similar, then fine, though I would put in blocking diodes to stop any of the panels being backdriven by the others, especially if they have different orientation or shading.
Logged
Podcast:
https://www.earth.org.uk/SECTION_podcast.html
kittysmitty
Jr. Member
Re: Mixing Panels
Reply #2 on:
January 11, 2015, 08:47:01 AM »
Currently the two 100 watt panels are pole mounted. The new three 135 watt will be roof mounted, so blocking diodes might be necessary. Would you use separate diodes for each panel, or one for the pole panels and one for the roof panels? Thanks
Logged
Administrator
Country:
Re: Mixing Panels
Reply #3 on:
January 11, 2015, 08:51:17 AM »
You might as well do them separately; it's probably as easy and may well cost the same, and gives you some additional resilience and comfort if something unexpected happens (like a gull dumping on one panel)!
Logged
Podcast:
SuperHero Member
Re: Mixing Panels
Reply #4 on:
January 11, 2015, 12:07:04 PM »
I have ground mounted panels pointing 3 directions to compensate for shading and variable clouds/weather. Two controllers are used and are maxed out for wattage. Controllers have embedded diodes on the output so I don't need to add any. I do have schottky diodes on some panels to prevent losses from shading. My panels are series in pairs for higher voltage which also gives better charging during shading/overcast weather.
I would love to roof mount, but that would mean codes and inspections and I would also have to own the place.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Solar
Mixing Panels
