Author Topic: Need help finding/selecting the right generator for a small wind turbine  (Read 1950 times)
Lukeiy
Hello!
I've designed a small wind turbine which should absorb 10-20 watts at 450-600 rpm (depending on the tip speed ratio I end up deciding on). I need some help with places to look, and the type of generator I should aim for that will give good reliability.  I would rather go direct drive and avoid the gears but I can't find anything that fits these specifications, any help is appreciated!
stofanel
Re: Need help finding/selecting the right generator for a small wind turbine
« Reply #1 on: September 17, 2015, 04:25:00 PM »
For this kind of power, I would consider stepper motors.
Lukeiy
« Reply #2 on: September 20, 2015, 01:56:08 AM »
For anyone interested, I found this little guy
http://small-generator.com/buy/index.php?main_page=product_info&cPath=1&products_id=31
Assuming ~60% efficiency it should take about 18W and output 12W at 500RPM
« Reply #3 on: September 20, 2015, 04:24:00 PM »
That 500RPM to get 6V is a bit steep.
Most stay away from that kind of speed.
Here's a link to our classifieds and what you can get for about $75/US.
http://www.fieldlines.com/index.php/topic,148809.msg1034869/topicseen.html#msg1034869
Being that your flag shows you to be in New Zealand, I'm certain there's something similar available closer that USA :).
Otherwise go looking for an ECM motor, unless of course you have a special need for the alternator to be small.
Best
