Author Topic: 3 phase AC wiring  (Read 1622 times)
gblass
3 phase AC wiring
« on: October 12, 2015, 06:48:52 PM »
Hi All
I will be putting up my SkyMAX Wind 750 Watt 24 Volt Wind Turbine in a few weeks.  The turbine is 3 phase output so can I use standard romex house wire from the turbine to the rectifier about 100 ft away?  If so what size would you recommend.
Thanks in advance.
George
5kw Grid Tied Solar.  1kw Solar with batteries and Midnite Solar charge controller. 600W Skymax Wind Turbine on 30FT tower.  80 gal Solar Water Heater.
Re: 3 phase AC wiring
« Reply #1 on: October 13, 2015, 04:49:15 PM »
Romex isn't rated for outdoor use or for burial. Wire rated UF-B is. Size your wire from this chart (pdf).
http://www.gocsc.com/pdf/5973024.pdf
gblass
« Reply #2 on: October 13, 2015, 05:31:46 PM »
dnix71 - Thanks for the info. that's just what I needed.  I wasn't sure if low voltage ac was different than standard 110/220.
About 10 ft from the tower is  an old 110 ac outlet that  has been disconnected for years. It was for a swimming pool and is run in conduit back to the electrical panel.  My plan is to run the wire from the tower in a short pc of conduit to a junction box were the 110 plug use to be then at the other end hook it to the charge controller.
Thanks again !
George
