Author Topic: A 6V wincharger  (Read 4293 times)
vassile52
A 6V wincharger
« on: October 15, 2015, 11:55:04 PM »
I did buy it a few day ago
vassile52
Re: A 6V wincharger
« Reply #1 on: October 15, 2015, 11:56:04 PM »
A 6V wincharger
vassile52
Re: A 6V wincharger
« Reply #2 on: October 15, 2015, 11:56:59 PM »
A 6V wincharge
vassile52
Re: A 6V wincharger
« Reply #3 on: October 15, 2015, 11:58:48 PM »
A 6V wincharger
vassile52
Re: A 6V wincharger
« Reply #4 on: October 16, 2015, 12:00:48 AM »
A 6V wincharger
vassile52
Re: A 6V wincharger
« Reply #5 on: October 16, 2015, 12:02:55 AM »
A 6V wincharger
Re: A 6V wincharger
« Reply #6 on: October 16, 2015, 12:14:12 PM »
Looks like a 50s -60s. Auto gen....it will need a battery hooked up to it ,,to start  charging...
Isaiah
Re: A 6V wincharger
« Reply #7 on: October 16, 2015, 12:44:49 PM »
Looks home made to me I have a 6 v Wincharger . it wouldn't be hard to change yours to 12 volt or find one of those 12v 120volt alternators should go right on your mount.
 Type in wincharger on ebay and see what may come up.
Re: A 6V wincharger
« Reply #8 on: October 16, 2015, 03:29:45 PM »
Sure looks like an old Ford 4N tracker's generator ! check it with a piece of tin, see if it has any residual magnetism. Itll be very low on outside of iron casing. IF there is any you're in luck .
Generator's of those days are very robust, not as efficient as today's alternators.
The little black box on outside is the regulator (probably) will have adjustable points in there.
The magnets inside were NOT very strong! similar to the ceramic of today, only curved.
I imagine you will not have any issues or it over speeding on you :).
It also looks like the spring setup was a tilt up to take it out of high high wind speeds.
I would also guess a 3 bladed prop setup could be used, BUT the tilt-up would probably need serious re-work.
Nice find!!
sean_ork
Re: A 6V wincharger
« Reply #9 on: October 16, 2015, 05:40:00 PM »
Very common dynamo Lucas C39/40 along with a mechanical controller, RB340 or similar.
Re: A 6V wincharger
« Reply #10 on: October 17, 2015, 01:37:50 PM »
Goggle search...they were auto gens far back as the 40s...I used the part number off  the gen 😜
