Author Topic: Shut off switch  (Read 1434 times)
go4it
Shut off switch
« on: January 08, 2016, 01:41:06 PM »
i want to change the way I shutdown my 12v windmill. I wonder if I can get away with leaving the ground connected and adding a two way switch that connects the windmill positive to either the battery positive or the common ground?
mab
Re: Shut off switch
« Reply #1 on: January 08, 2016, 07:34:47 PM »
So the mill is either connected to the battery or shorted? I guess that would work - but make sure it's a proper break-before-make switch, and make absolutely sure you can't confuse the connections to the switch 'cos you don't want to short the battery to gnd instead  :) .
klsmurf
Re: Shut off switch
« Reply #2 on: January 08, 2016, 08:56:35 PM »
I guess you're talking about a DC mill?  I was told that shorting a DC mill like that was not good.  High speeds may burn the mill up.  I believe it was Ghurd that
suggested to load the mill with some lights to slow it down first.
go4it
Re: Shut off switch
« Reply #3 on: January 08, 2016, 09:32:09 PM »
I try not to stop it if it is spinning quite fast by I have had to stop it in a high wind and it stopped without incident.
