Author Topic: Maxing out my small off-grid system  (Read 22004 times)
Re: Maxing out my small off-grid system
« Reply #33 on: July 30, 2016, 11:36:24 AM »
I shall have a go at the new holes in the frame today or tomorrow.
I shall put tape on the bit and a ceramic tile and maybe cardboard behind the part of the frame I am drilling to protect the panel itself.
« Reply #34 on: July 30, 2016, 02:03:09 PM »
OK, did a first test hole.  Rather slowly, but without drama.  Thanks for the advice!
Wasn't sure the best way to clean the swarf/nasties on the rear of the drilled hole, so for now flattened them with pliers to literally take the edge off them and allow the nut to sit flat.  What would a responsible adult do given that access is tricky...
« Reply #35 on: July 30, 2016, 05:47:33 PM »
When drilling aluminum you can cut down on the ragged exit hole by drilling slow with very sharp bits. The aluminum should come off in a constant curl and not in chips.
« Reply #36 on: July 31, 2016, 11:00:01 AM »
Thanks!
I was going slow, out of cowardice as much as anything else.  I don't have a choice of bit at the moment.
About to do the first real set of 4, and *may* get to mount the first panel today...
« Reply #38 on: August 03, 2016, 03:54:56 PM »
More frame-drilling fun, and removal of older panels today.  Hoping to put second 255W panel up tomorrow!
« Reply #39 on: August 04, 2016, 06:07:39 AM »
Yeah!  Second panel up and connected...  B^>
« Reply #40 on: August 05, 2016, 05:04:10 PM »
Latest schematic:
with half-decent charge to the batteries today:
« Reply #41 on: August 06, 2016, 02:08:41 PM »
Looks good:  I can see Bulk + Float appear in the plot.
You don't have to ground the battery negative to earth... as long as nothing else in the system is earthed either.
« Reply #42 on: August 06, 2016, 02:43:26 PM »
Yes, more than one real-life electrician has suggested that leaving the entire system to float is probably best.
« Reply #43 on: August 10, 2016, 09:59:03 AM »
Next part of my plan for world domination (Mwahahahahaha) involves my shiny new Morningstar PC MeterBus Adapter for my SS-MPPT-15L controller which arrived today.
The aim is to use the controller's measurement of (a) battery voltage and (b) battery charge current and/or SoC wholly or partly in place of values measured (or computed/guessed) at the RPi.
I'm hoping that this improves my ability to handle bigger loads (without being panicked by apparent sag) for example.
Anyway, I get to learn some MODBUS, which should be fun.
PS. Minutes after finally relenting and buying the Meterbus RS232 adaptor that I had been considering for years, and working out how to interface it to USB for my RPi for example, I noticed that there is a USB version of the Meterbus adaptor which would be simpler and probably more power efficient.  Oh well.
« Reply #44 on: August 23, 2016, 04:55:22 PM »
Even clearer here:
http://www.earth.org.uk/MODBUS-and-Raspberry-Pi.html#20160823
« Reply #45 on: September 11, 2016, 04:53:15 AM »
Update:
1) I've seen the controller hitting its max 15A into the batteries, at slightly over 200W power from the array.
2) Currently the ratio of power from the roof to power from the off-grid array is about 30:1 even though the array size is about 10:1.  If my over-build experiment is to 'work' this ratio had better improve in favour of the off-grid system by mid-winter!
3) I've tracked down some of the supply impedance that I was detecting, ~0.1 ohm from battery to input to the RPi 12V-to-5V switch mode supply (Vbus).  I'm taking measurements at the battery and load terminals of the controller, and Vbus, and an output snippet from my program with the system under some load is:
Code: [Select]
Verbose mode ($Id: powermng.cpp 15411 2016-09-11 08:40:19Z dhd $).
SS-MPPT-15L Vb_f slow battery voltage (mV): 12473
SS-MPPT-15L Adc_il_f load current (mA): 1472
Load power (mW): 18361
Input flag DUMPING is unset.
SS-MPPT-15L Adc_ic_f battery charge current (mA): 658
External flag file /var/log/SunnyBeam/LOW.flag is absent.
ADC command 6a 80
ADC (6a 0) response 1307 (5 1b 0)
Battery voltage 1 local (LA) 12262mV, 2 (Li) -1mV.
Supply drop B1 to BV 211mV; implied supply impedance 0.143342ohm.
Adc_vl_f load voltage (mV): 12397
Supply drop controller to BV 135mV; implied wiring impedance 0.091712ohm.
The upshot is that maybe 1/3rd of the voltage drop I see happens between the battery and load terminals of the controller, probably as part of its measuring and short-circuit protection.  The rest is still higher than I'd like (and the lumpiness of the measurement for small voltage drops means that these absolute values are probably only roughly right), but at least its getting closer to my estimates of what it should be.
I took the opportunity to tidy up the wiring yesterday.
4) It was open day at my house yesterday for SuperHomes and again today and I get to show off my little off-grid system to the visitors!
http://www.superhomes.org.uk/superhomes/london-kingston-upon-thames-willingham-way/
« Reply #46 on: February 18, 2017, 12:07:08 PM »
That didn't work then:
http://www.earth.org.uk/expanding-off-grid-PV-system.html#20170218-no-500Wh
More like 150Wh/d rather than the target 500Wh/d, mid-winter!
jwgorman
  • Country: nz
    • SolarNetwork Foundation
« Reply #47 on: February 05, 2018, 07:05:47 PM »
This is very interesting - I know that you can grab the data from a Morningstar controller over RS232 (Modbus) but do you know if there are any battery chargers you can command via Modbus?
« Reply #48 on: July 06, 2018, 03:48:56 PM »
Sorry, missed your post.
That Morningstar practically IS a battery charger; you can connect anything within the Vmax to its inputs and it'll current limit inputs and outputs to charge the battery.  And it will take all sorts of instruction over MODBUS, though I am deliberately only reading from it.
I'd be astonished if there was not a pure charger that would take instruction.  Maybe another Morningstar device, for a start.
