Author Topic: Control for heating with solar off grid no batteries  (Read 77457 times)
0 Members and 7 Guests are viewing this topic.
Re: Control for heating with solar off grid no batteries
« Reply #165 on: January 18, 2019, 08:07:45 PM »
wiring the remote to it won't work, might be cheap enough to get a $1-2 IR receiver off ebay and just use the IR transistor off of it...https://www.ebay.com/itm/5PCS-KY-022-37-9KHz-Infrared-IR-Sensor-Receiver-Module-For-Arduino-AVR-PIC-NK/163471595029?hash=item260faa9615:g:E14AAOSwWI5cMdK1:rk:51:pf:0
ontfarmer
« Reply #166 on: January 22, 2019, 10:35:31 AM »
I have no problem getting that.  Would need help,  diagram to install it.  Are there ratings on these or are they universal ?   Can the one be left at the panels and another one be added to the  wire in the house ?   I know nothing about this.  HELP
frackers
  • Country: nz
  • Picard spits "Hello"
« Reply #167 on: January 22, 2019, 06:39:33 PM »
Not all IR receivers are the same!
They operate at a fixed carrier frequency, usually one of 38KHz, 40KHz or 56KHz and they have inbuilt filters that can affect the maximum bit rate (I know the TSOP34156 for example can handle 4kb/s data but that's about it!!).
« Reply #168 on: January 23, 2019, 06:14:54 PM »
Yeah it is goin to be potluck getting the right one... unless there is a number on the bad part...
ontfarmer
« Reply #169 on: January 25, 2019, 10:10:18 AM »
 Here is the number  4844S on the other side KU
« Reply #170 on: January 25, 2019, 03:21:25 PM »
Batting zero on that part number... maybe contact the board manufacturer and ask them?
ontfarmer
« Reply #171 on: March 25, 2019, 05:42:46 PM »
Update  There has been very little sun here since last fall  ( kind of depressing )  We are starting to get
 a few sunny days now.  I'm very happy with the increased power from the panels tracking the sun.
I have been adjusting the tracker to follow the sun.  Installed a battery to power the actuator going to try and get charging from the panels.
OperaHouse
« Reply #172 on: March 26, 2019, 02:05:20 PM »
I haven't been able to find that IR module in an old VCR.  I did just find a stock of photo transistors while searching for something else.  These should work as a repeater for anything.  It will just have to be shielded to keep out outside light because it won't be able to filter out ambient light.  That shouldn't be a problem.
ontfarmer
« Reply #173 on: March 28, 2019, 06:42:15 AM »
That is great you found the photo transistors.  I have been pointing up the stone foundation on the house, picking up limbs, the usual spring clean up.  Sometime when you get a chance I will try to get that working.
