Author Topic: axial generator with lamination core  (Read 221499 times)
mbouwer
Re: axial generator with lamination core
« Reply #462 on: May 23, 2021, 04:56:59 AM »
Front view. Added the blade suspension.
« Reply #463 on: May 24, 2021, 10:11:40 AM »
very nice even coats of paint.
Do you powder-coat them ?
Thanks!
mbouwer
« Reply #464 on: May 24, 2021, 11:41:24 AM »
By using paint (aerosol) I try to show a clear picture on the forum.
Now am I doing to make a blade suspension for 90 cm long blades.
And want to bear the blades in rubber rings to make things less heavy.
This stuff should become the blade shafts.
mbouwer
« Reply #465 on: May 25, 2021, 01:54:49 PM »
Double wall base rings for the rubber bearings.
Especially when scaling up this sandwiching can save a lot of weight.
kitestrings
« Reply #466 on: May 26, 2021, 04:04:39 PM »
The rubber is the bearing that will allow the blades to pivot, is that correct?  I think I asked this before, but is there a means of tying the three rings on the outer-side of the blade plane (away for the tower)?  It seems like structurally this would be needed; at scale.  Looking good.
mbouwer
« Reply #467 on: May 27, 2021, 05:50:21 AM »
The rubber is meant to construct lightly with no play.
Do you mean attachment to wooden blades?
Like Midwoud who clamped the blades between 2 steel plates.
kitestrings
« Reply #468 on: May 27, 2021, 04:12:40 PM »
No, I was talking about the hub.  In your picture at #461, we can see the three points of attachment for the blades, but on the side away from the connection to the yaw bearing are those flanges tied?
Similarly, on the latest photo from Midwoud turbine there is a metal ring on the top of the assembly.  This would seem to offer a lot more strength to the assembly.
mbouwer
« Reply #469 on: May 28, 2021, 03:15:05 AM »
You're right, but that kind of reinforcements can be added later on.
First I want to assemble the pitch mechanism.
kitestrings
« Reply #470 on: May 28, 2021, 04:07:49 PM »
Just curious... have you heard anything recently from Midwoud.  I haven't seen any updates on his turbine.  Hopefully he's well.  ~ks
midwoud1
« Reply #471 on: May 29, 2021, 04:09:30 PM »
Hi Kitestrings
I'm okay . We moved to an other place. I can not instal my windmill here . Hopefully later with more space.
My windmill is sleeping on the attic.
Still follow  Fieldlines. And mbouwer designing his windmill, speak him every week.
Wish you all the best  . Frans ( midwoud1 )
mbouwer
« Reply #472 on: May 30, 2021, 12:29:00 PM »
Midwoud had it well organized.
As you also can see in his videos on youtube, he always had the quietly rotating Piggott in hand because it was equipped with blade adjustment.
« Reply #473 on: May 30, 2021, 09:28:35 PM »
Thank you Midwoud for checking in.  You are always welcome to stay in touch.  Hope you can put your machine back in the air soon!
mbouwer
« Reply #474 on: June 22, 2021, 12:11:28 PM »
Movement mechanism to pitch the blades.
First version of a small axial direct drive motor.  9 coils and 2x10 magnets. Low rpm speed / High torque.
The hub ( = nut M 16 ) turns around the axle ( = threaded rod M 16 )
This rod then makes a longitudinal movement to adjust the blades.
mbouwer
« Reply #475 on: June 24, 2021, 04:35:30 AM »
This is the matching controller I bought.
mbouwer
« Reply #476 on: June 27, 2021, 11:42:08 AM »
This is how the packages and the coils are arranged.
I wonder if there is not an easier possibility to shape the steering of the motor.
mbouwer
« Reply #477 on: June 29, 2021, 09:37:42 AM »
motor version 1
72 revolutions per minute.
The torque is more than sufficient.
« Last Edit: June 29, 2021, 12:47:16 PM by mbouwer »
mbouwer
« Reply #478 on: August 08, 2021, 09:16:56 AM »
Would it be possible to get an exchange of views on this forum with windmill builders who actually apply active pitch control?
And to discuss the developments.
« Reply #479 on: August 09, 2021, 11:11:25 PM »
Hey,
Sorry for missing your post about testing the generator.  It's passed its first electrons.  What did you observe when you ran it (as a motor, I assume)?
mbouwer
« Reply #480 on: August 10, 2021, 08:48:10 AM »
The axial motor is part of my blade pitching test setups.
The blade suspension, the controls, the steering of the blades...
All quite complicated, so I want to discuss how to make it simpler.
mbouwer
« Reply #481 on: August 12, 2021, 09:05:52 AM »
The blades of the large turbines are suspended from heavy slew bearings.
But it seems to me that we have to find a lighter way.
mbouwer
« Reply #482 on: August 13, 2021, 08:57:42 AM »
Should we look for it in a way I showed earlier? ( Reply #87 )
No doubt there are windmillfriends on this forum who have other ideas.
« Reply #483 on: August 13, 2021, 09:14:25 AM »
There may be, but we're all in awe of your manufacturing skills!!
kitestrings
« Reply #484 on: August 13, 2021, 09:30:03 AM »
That (#87) seems like a design worth trying; probably lighter than the slew bearing concept.
I think one thing I might contemplate changing, would be to look at attaching or fabricating a metal flange plate for the blades on the assembly.  Introducing a shaft "pocket" into the root of the blades seems like might add complexity and potential for water infiltration, and corrosion.
mbouwer
« Reply #485 on: August 14, 2021, 12:10:19 PM »
Perhaps it is an option to make the root of a wooden blade nicely round like a thick round pole.
Shaping a polyester cuff around it.
And then in that bearing letting it rotate that ​80 degrees.
« Last Edit: August 14, 2021, 12:22:28 PM by mbouwer »
mbouwer
« Reply #486 on: August 15, 2021, 10:07:27 AM »
Isn't it easier to form the blades from foam cores,
which you then cover with a few layers of polyester?
mbouwer
« Reply #487 on: August 19, 2021, 12:10:03 PM »
In the meantime I am working on an electric garden tractor.
Based on the model John Deere 3020
« Reply #488 on: August 19, 2021, 02:48:42 PM »
What type of battery chemistry will you be using?
mbouwer
« Reply #489 on: August 20, 2021, 06:45:26 AM »
Initially I want to use the stuff from an electric wheelbarrow.
But first shaping the mechanical parts.
Just finished the axle housings and sprayed it with John Deere green.
« Reply #490 on: August 20, 2021, 09:09:39 AM »
Could you expand on the electric Wheelbarrow ?
Many Thanks
mbouwer
« Reply #491 on: August 21, 2021, 09:31:42 AM »
First let's see if I can get this small tractor to work.
mbouwer
« Reply #492 on: August 22, 2021, 01:47:28 PM »
The size of the professional turbines is increasing (Moving towards 20 MW )
Striking are the gearboxes.
A small test setup with a gear box seems nice to me.
« Last Edit: August 22, 2021, 03:00:21 PM by mbouwer »
mbouwer
« Reply #493 on: August 23, 2021, 10:30:47 AM »
In a previous test set up I had connected two separate gear boxes.
But it seems to me that it can also be more compact with one single gearbox.
mbouwer
« Reply #494 on: August 29, 2021, 09:31:28 AM »
When applying a light solid transmission between the main shaft and the generator I do need much less copper and neodymium.
Below the rear and front axle for my electric tractor.
« Last Edit: August 29, 2021, 10:01:45 AM by mbouwer »
