Author Topic: axial generator with lamination core  (Read 221219 times)
0 Members and 8 Guests are viewing this topic.
mbouwer
Re: axial generator with lamination core
« Reply #99 on: October 18, 2018, 04:30:37 AM »
Blade pitching bars.
mbouwer
« Reply #100 on: October 20, 2018, 04:23:54 AM »
Cardboard mould to shape the spinner.
mbouwer
« Reply #101 on: October 23, 2018, 06:52:52 AM »
3m. diameter blades + spinner. Now I want to apply sealing collars around the blade roots.
mbouwer
« Reply #102 on: October 28, 2018, 05:19:13 AM »
The suspension and the sealing of the blades is now light, but I find it is too complicated to fabricate.
I would like to try to shape it in a simpler way with a larger blade root.
« Last Edit: October 28, 2018, 05:23:23 AM by mbouwer »
mbouwer
« Reply #103 on: November 01, 2018, 04:13:09 PM »
The best would be to shape the whole suspension and blade bearing in composite.
« Reply #104 on: November 03, 2018, 11:22:45 PM »
Difficult to understand that last point, Mbouwer.  Composites of all kinds are not strong against bearing stress, and they definitely do not hold a good surface finish when exposed to alternating pressure, as bearings do.
mbouwer
« Reply #105 on: November 05, 2018, 01:07:20 PM »
Let us discuss the blade suspension bearings. How can we shape a good design?
I think we can not use the type of heavy slewing ring bearings like we see in the big turbines.
« Last Edit: November 05, 2018, 01:16:22 PM by mbouwer »
« Reply #106 on: November 05, 2018, 07:26:26 PM »
Certainly.  You start.  What do you actually plan to use?
mbouwer
« Reply #107 on: November 06, 2018, 05:25:55 AM »
As you can see on this page, and in all my contributions to the forum, it is my intention
to search for cooperation with windmillfriends for improved designs.
 In reply #87  I show steel shafts and composite hubs.
 It seems to me that the axes also should be performed in composite.
« Last Edit: November 06, 2018, 05:33:23 AM by mbouwer »
mbouwer
« Reply #108 on: November 08, 2018, 04:24:08 AM »
Perhaps blade adjustment will become more and more a hot item at this forum
if we can 3D print the blade bearings
« Last Edit: November 08, 2018, 04:54:43 AM by mbouwer »
« Reply #109 on: November 08, 2018, 08:51:32 PM »
Interesting.
The limitations in those ideas will become apparent to you soon, since you are so close to final assembly.
mbouwer
« Reply #110 on: November 11, 2018, 06:13:10 AM »
In the course of time more cooperation amongst windmillfriends will arise,
and then there are almost no limitations.
mbouwer
« Reply #111 on: November 15, 2018, 06:52:31 AM »
Blade bearings molds have to be made.
As a starting point I want to take sealing rings 100 x 125 mm around the blade roots.
mbouwer
« Reply #112 on: November 29, 2018, 02:20:07 PM »
Tryout to shape a mould for the blade axle.
mbouwer
« Reply #113 on: December 01, 2018, 06:03:08 AM »
Polyester blade axle ( 300 gram )
The idea is to insert the raw edge in the polyester of the spinner.
mbouwer
« Reply #114 on: December 02, 2018, 04:32:35 AM »
Hub mould with an edge to shape a suitable space for the blade root sealing.
« Last Edit: December 02, 2018, 05:06:27 AM by mbouwer »
mbouwer
« Reply #115 on: December 03, 2018, 07:45:41 AM »
The hub has to be inserted in the polyester blade root.
The aim is that the bolt and nut, together with the slide bearing, can shape a rotatable blade suspension.
mbouwer
« Reply #116 on: December 06, 2018, 03:07:35 AM »
Lightweight blade axle and hub.
Now I want to pull apart the bearing positions to an intermediate size of 0.5 m.
mbouwer
« Reply #117 on: December 08, 2018, 05:17:48 AM »
Modified mould.
mbouwer
« Reply #118 on: December 11, 2018, 04:49:26 AM »
Polyester blade axle (683 grams)
I want to make another one with a mounting flange.
mbouwer
« Reply #119 on: December 22, 2018, 12:48:41 PM »
Figuring out how to make a steel version with a minimum of material.
mbouwer
« Reply #120 on: December 24, 2018, 10:18:50 AM »
The cuff. Later on I want to revolve it on 100 mm diameter in the lathe.
mbouwer
« Reply #121 on: December 31, 2018, 09:32:02 AM »
Steel blade axle 1398 grams.
If I can adjust the mould of reply#117 with a flange
the polyester implementation seems better suited.
mbouwer
« Reply #122 on: January 01, 2019, 12:18:05 PM »
Happy new year to all windmillfriends.
« Last Edit: January 01, 2019, 12:51:55 PM by mbouwer »
« Reply #123 on: January 02, 2019, 11:30:46 PM »
You too!
Thank you Mbouwer, for keeping up the progress.
We look forward to seeing the result this year, I hope!
mbouwer
« Reply #124 on: January 03, 2019, 11:58:28 AM »
Thanks Sparweb,
It's all about sustainable energy
and I find it a wonderful hobby.
mbouwer
« Reply #125 on: January 05, 2019, 08:56:58 AM »
Back on the test stand. The generator composition as a base to mount the blade axles.
« Last Edit: January 05, 2019, 09:22:40 AM by mbouwer »
mbouwer
« Reply #126 on: January 15, 2019, 01:54:25 PM »
To shape some adjustments on the forward magnetring I taped the magnets.
mbouwer
« Reply #127 on: January 17, 2019, 05:57:28 AM »
Pressed air, vacuuming, sticky tape,
it is not yet easy to get the steel dust particles of between the magnets.
mbouwer
« Reply #128 on: January 24, 2019, 03:26:54 PM »
On this basis, I would like to make an improved implementation.
« Reply #129 on: January 25, 2019, 10:51:15 PM »
What would you like to improve?
Do you want to test the performance of what you have done so far?
mbouwer
« Reply #130 on: January 26, 2019, 05:04:05 AM »
My belief is that axially with laminated iron core in the coils is a good starting point.
But I think I can improve my workpiece regarding for example:
manufacturing technique
stiffer frame
smaller diameter
more precise gap width ajustment
« Last Edit: January 26, 2019, 05:21:19 AM by mbouwer »
« Reply #131 on: January 26, 2019, 12:10:02 PM »
You will not know what you need to improve until you put your machine into service.
I (and probably many others) have been eager to see your machine fly for a long time.
You are so close now, don't give up hope!
