Author Topic: Machine tools  (Read 4050 times)
JW
  • Development Manager
    • Flashsteam.com
Machine tools
« on: January 05, 2018, 04:38:59 PM »
I use this lathe for finishing fitment stuff like that
11028-0
These are the bits that I use to cut they are carbide
11029-1
I got lucky with these bits because shimming is minimal they are level with the turning axis.
11030-2
these are used to cut the valve seat. I have a tail stock with drill chuck to use these.
My source is- http://www.grizzly.com for regular tool bits, I also use https://www.mscdirect.com/
Had to think about it for minute, the seat cutters are custom made.
« Last Edit: January 05, 2018, 08:00:45 PM by JW »
XeonPony
  • Sanity is over rated!
Re: Machine tools
« Reply #1 on: January 05, 2018, 11:02:52 PM »
perhaps it is laziness but I tend to file for my finish fit, then lap to final fit, rarely did I ever just turn them down other then ruffing.
As in another thread when I can will be geting a small bench lathe and when finally on some acreage a full sized lathe, I miss having tools as it is a serious slow down to getting the new wind turbine don.
Re: Machine tools
« Reply #2 on: January 06, 2018, 08:59:44 AM »
i modified a tiny wood lathe with a thee jawed chuck and a  drill chuck on the tail stock. very limited as to what i can do with it but still, comes in handy.
george65
Re: Machine tools
« Reply #3 on: January 06, 2018, 09:23:42 PM »
Sometimes you can do a lot with just a little.
Just that bit more flexibility and capability can result in a disproportionate amount of the wider range of jobs you can do with something.
Re: Machine tools
« Reply #4 on: January 07, 2018, 12:33:44 PM »
I never know how lucky I was until it was gone.
For 16 years I worked at an aerospace prototype engineering shop and had access to lathe, NC mill, regular vertical mill, welding, and all sorts of sheet-metal equipment, and a trusting relationship with the owner (very small company) so that I could so lots of weekend projects.  Then he retired and I had to get a bland office job.
