Author Topic: gear box study  (Read 9103 times)
mbouwer
Re: gear box study
« Reply #33 on: February 28, 2018, 08:06:17 AM »
The configuration that I have in mind.
This gives space for the active pitch control box.
« Last Edit: February 28, 2018, 08:17:16 AM by mbouwer »
mbouwer
Re: gear box study
« Reply #34 on: March 01, 2018, 09:24:22 AM »
Now first I want to modify stage no.1 for reduced weight and smaller dimensions.
Outside diam. of the new shaft is 50 mm.
« Last Edit: March 01, 2018, 09:32:11 AM by mbouwer »
dbcollen
Re: gear box study
« Reply #35 on: March 01, 2018, 11:21:10 AM »
Nice work, but aren't you putting the cart before the horse. You are building this transmission with no alternator that you are trying to match.
mbouwer
Re: gear box study
« Reply #36 on: March 01, 2018, 02:20:53 PM »
You're right,
But I think building small windmills is more fun, and there are more possibilities, being part of a team.
By showing my capabilities in this kind of studies I hope to once become part of a team.
In my region or elsewhere.
« Last Edit: March 02, 2018, 05:22:18 AM by mbouwer »
mbouwer
Re: gear box study
« Reply #37 on: March 03, 2018, 09:30:34 AM »
Next step is mounting the two gearboxes.
As a base the yaw bearing from Active Pitchcontrol Reply #830
The frame between the yaw bearing and gear box no. 1
mbouwer
Re: gear box study
« Reply #38 on: March 05, 2018, 08:35:19 AM »
Now adding stage 2
mbouwer
Re: gear box study
« Reply #39 on: March 06, 2018, 09:00:01 AM »
Mounting bracket for stage 2 on the yaw bearing.
mbouwer
Re: gear box study
« Reply #40 on: March 07, 2018, 08:08:22 AM »
Stage 2 + drive shaft.
mbouwer
Re: gear box study
« Reply #41 on: March 09, 2018, 04:19:59 AM »
Modified main axis flange to mount the blade suspension on.
« Last Edit: March 09, 2018, 04:27:55 AM by mbouwer »
mbouwer
Re: gear box study
« Reply #42 on: March 10, 2018, 08:46:32 AM »
Blade suspension. It is shaped such a way
that my previous made blade bearings fit.
« Last Edit: March 10, 2018, 08:51:48 AM by mbouwer »
mbouwer
Re: gear box study
« Reply #43 on: March 13, 2018, 04:36:28 AM »
For now I would like to end this gear box study.
Re: gear box study
« Reply #44 on: March 13, 2018, 08:34:06 AM »
congratulations on the completion of your machine mbouwer. i think it may be the most complex ever posted.
Re: gear box study
« Reply #45 on: March 13, 2018, 12:45:43 PM »
Nice...so how did it perform..?
mbouwer
Re: gear box study
« Reply #46 on: March 14, 2018, 05:24:53 AM »
Driven by the blades it produces the typical humming noise.
Later on I want to shape a three stage gearbox to get a greater ratio to drive a asynchronous 220/380 volt motor as a generator
Re: gear box study
« Reply #47 on: March 14, 2018, 11:10:45 AM »
Cool...next full size.?
Re: gear box study
« Reply #48 on: March 15, 2018, 03:00:50 PM »
Mbouwer,
It look great!
Well done!
I have enjoyed watching your progress every step of the way.
