Author Topic: Hubless and Masterless Outback Inverter Usage  (Read 1932 times)
Eraser3000
« on: December 26, 2018, 12:53:33 PM »
Does anybody have any experience getting the Outback VFXR Series Outback inverters to run without the Outback Hub ?
Essentially I want to be able to run the Battery Inverters more like the String inverters but also be able to deliver power from batteries when required.
I have this working on the bench with two inverters and will be retrofitting this into the rest of my system, but I though I would try to get some feedback from anyone else already doing this.
Thanks!
Eraser3000
Re: Hubless and Masterless Outback Inverter Usage
« Reply #1 on: December 26, 2018, 01:18:07 PM »
11581-0
Eraser3000
« Reply #2 on: December 29, 2018, 09:31:09 PM »
Yellow is Test Inverter 1, Green is Test Inverter 2
Red is a 0 to 15 volt Square wave, Slave Inverter syncs with this Square wave.  This is on Pin 4 of the RJ45 on the inverters.
11587-0
Eraser3000
« Reply #3 on: December 29, 2018, 09:39:50 PM »
Red is Data line Pin 5 on RJ45   Serial uart running at 1200 8N1 .  This has to be there and is transmitted at 60Hertz
My guess is the voltage is so high because the anticipated running up to 10 inverters on 1 hub and have to account for max distances on all of the cat5 between hub and inverters.
This is interesting in that  00001111 = F = 15 = Ascii (SI) =   yes! the Sun, very nice touch!
Eraser
Eraser3000
« Reply #4 on: December 29, 2018, 09:41:27 PM »
