Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Controls
(Moderator:
Alternative Power Inverter design
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Alternative Power Inverter design (Read 2233 times)
daviddawe1982
Newbie
Country:
on:
February 05, 2019, 09:52:22 AM »
Hello All,
I have been playing around with a custom inverter build and while programming the controller I had a thought.
50/60Hz is not ideal for a voltage conversion frequency so why not do the dc to ac at say 100khz then rectify that back to dc then run a second H bridge to modulate the high voltage dc at 50hz.
It would require a smaller transformer and the HV side switching would only require a few MOSFETs...
I the first thought was a high current boost step-up circuit but I would then get voltage spikes as loads came on and off.(Please correct me if I am wrong).
So my current idea is..
DC LV HF h bridge -- Smaller Transformer -- Full Bridge Rectifier -- DC HV LF h bridge -- Filter For Sine.
What are peoples thorghts ?
Has it been done and did it work?
Just thought I would ask before going to far off track with my current design.
Thanks.
Logged
petect
Jr. Member
Re: Alternative Power Inverter design
Reply #1 on:
February 05, 2019, 10:49:32 AM »
Hi Dave
Have you been to
https://www.thebackshed.com/forum/home.asp
Your fellow Aussies are doing a lot with inverters there.
Pete
Logged
Hero Member
Country:
Reply #2 on:
February 05, 2019, 01:07:11 PM »
What you've described is whats in most cheap modified sine wave inverters, many computer backup supplies. and many sine wave inverters.
Above maybe 5KW, a 60hz transformer can compete with a double conversion dc-ac-dc-ac inverter.
Logged
mab
Sr. Member
Country:
Reply #3 on:
February 06, 2019, 06:46:23 PM »
well it's certainly do-able, but I'm not sure the advantaage of a smaller transformer offsets the disadvantage of having a one-way inverter - with a big 50hz trans you can AC couple pv/ generators and backfeed the inverter - i don't think that works with 2 stage inverters. Also your surge capability tends to be limited by the capacitor bank storing your HVDC - hence the best inverters for starting motors are the low frequency type .
Logged
Print
Pages: [
1
Go Up
« previous
next »
Controls
(Moderator:
