Author Topic: Here is a night light project  (Read 3942 times)
MagnetJuice
« on: March 21, 2019, 03:16:48 AM »
I have a downstairs bathroom that sits close to the middle of the house. It has no windows and it is pitch dark when the door is closed. I had a regular night light, but I wanted something different that does not plug in, so I used two high power LED's and placed them into the switch cover.
These are 8 mm LED's designed to operate at 3 Vdc and 35 mA. They are very bright at 3 volts and light up with as little as 2.4 volts. With 3.8 volts, they are super bright. That seems to be the maximum voltage that they can safely take.
They are clear and blinding to look at, so I made them opaque by sanding them a little. Much better on the eyes that way.
I searched the WEB for a circuit to use but there is too much confusing opinions. I ended up experimenting until I found a suitable circuit. Many people use a single diode as a rectifier but I have many of those small bridge rectifiers so I used that instead. It greatly minimizes the flickering compared to the single diode. This is the circuit that I used.
11725-2
I started with a 47K ohm ½ watt resistor. It was OK but not bright enough. Then I tried a 20K ½ watt resistor. Very nice but the resistor got a little too warm. Next I tried a pair of 47K resistors in parallel which equals 23.5 K ohms. Nice and bright and the resistors stayed cool because they can dissipate 1 watt in parallel.
OK, time to wire up the thing. I put a fuse in the line for peace of mind. I used a ½ amp pigtail fuse because that was the smallest I had but something as low as 100 mA will work.
11726-3
The power going into the LED's is 5 Volts (that is 2.5 volts per LED) and only 4.5 mA. They will last a long time with that little current. Power consumption from the 120 Volts is about half a watt.
11727-4
I did not leave any of the wires exposed. I enclosed all the connections in heat shrink tubing or covered them with hot glue.
Anyone that wants to do this should be familiar with and feel comfortable working with high voltage. This voltage is high enough to hurt or kill. Kill is not a good word to end this so…
PEACE  :D
Ed
OperaHouse
Re: Here is a night light project
« Reply #1 on: March 21, 2019, 01:38:14 PM »
I did something even simpler.  Our hallway light is a 9W LED replacing an incandescent.  I just pulled the wall switch and put a .047uF capacitor across the switch terminals.  When not ON, LED is quite dim.  I've seen three different types of screw in lamps. One won't work at all, another will flash repeatedly (good for Halloween) as the inverters capacitor charges up and discharges, and most common will just glow dim.
« Reply #2 on: March 21, 2019, 10:57:43 PM »
Great idea!
MagnetJuice
« Reply #3 on: March 26, 2019, 03:10:05 PM »
Yesterday I put LED's in this outlet.
This outlet is in front of the stairs. I had a plug-in night light there but my wife had to unplug it all the time to plug in the vacuum cleaner. Now it is free and it illuminates the stairs really nice.
« Reply #4 on: March 27, 2019, 04:40:12 AM »
This battery nightlight (partly self-solar-charged) has done us for years:
http://www.earth.org.uk/LED-homebrew-nightlight.html
Basically needs an off-grid charge once per year to top-up at the end of winter.
« Reply #5 on: March 31, 2019, 08:54:43 PM »
Ed,
I'm really intrigued by your idea.  I've also been thinking of ways to make it simpler/cheaper.
How does this look to you?
« Reply #6 on: March 31, 2019, 08:58:54 PM »
Clicked "submit" too quickly...
The resistors do the step-down.  The capacitor is optional but may reduce the blinking.  The diode in series with the LED is not crucial, but I don't trust a LED alone with 120VAC.  The fuse is not shown in the circuit but I think it's a VERY good idea to have them.
« Reply #7 on: March 31, 2019, 09:20:03 PM »
Here's another.
I eliminated the capacitor.  I shouldn't have done that.  I also added a fuse instead.
If you want to try something cool, go to this site:  http://www.falstad.com/circuit/
...and load this file:
* circuit-20190331-1914.circuitjs.txt (0.33 kB - downloaded 253 times.)
MagnetJuice
« Reply #8 on: March 31, 2019, 11:37:23 PM »
That last circuit that you posted works OK. You might need to increase or decrease the resistance to get the right brightness depending which LED you use. The LED flicker will be worse with the single diode because you will only get half the wave from the AC sine wave.
There is not big savings by substituting the bridge rectifier with a single diode.
3 cents for the diode or 8 for the bridge. Five cents savings.
With 5 cents and $1.75 you can get a black coffee at Starbucks  :D
« Reply #9 on: April 01, 2019, 12:08:40 AM »
I don't know how I misled myself, but I thought you were using a bridge the size of a scrabble tile.
ontfarmer
« Reply #10 on: April 05, 2019, 07:42:58 AM »
Just got and installed a  .047uf capacitor across the terminals of the switch for the bathroom entrance light.  A great safety device!!  ( stubbed toes, black eyes )
« Reply #11 on: April 05, 2019, 02:51:32 PM »
I just leave the bathroom light on over the mirror, draws all of 8 watts... but it is on grid...
