Hi everyone!
Answers in order then-
Hello Adriaan,
I guess I could furnish more detail about the blade-to-generator matching process. My approach is very different from yours.
My previous 2.44 meter diameter blades were apparently under-sized for the turbine, and for that it really didn't matter if they had been cut to the correct TSR or not (which they weren't). When I first cut them, I was still playing around with the math learning to understand it. Today I have all the resources I need to work out exactly what's needed, and I wouldn't mind sharing it, if you like.
I use software known as "Mathcad" which permits analysis of engineering problems with any unit system I want. You can be confident that I use metric for my private aerodynamic calculations, but for my mostly north-american audience I usually report measurements in US customary units when I post to Fieldlines. This is probably not widely known, and when I explain it, sometimes it falls on deaf ears, but ever since Canada chose to use metric, but the US chose NOT to use metric, Canada has been in a units "purgatory" where we have to be aware of both and express ourselves one way for one person and a different way for another. I'm used to it, although I admit the US customary stuff still comes more easily.
Anyway, back to turbines:
I had measured, directly, the power input and output curves of my generator by driving it using a lathe. I am confident I've mentioned this to you before, and I documented some of this on Fieldlines, if you want to see my test apparatus and methods. The data allows me to compare many different blade profile and power output curves, to see which ones match the required input of this generator. I can even select different electrical connection schemes of the generator to improve the match, rather than choose different blades, if I want.
The essential conclusion is that a 2.4 meter rotor is too small, and this was borne out by the data I collected with my datalogger last year. Yes it took me several years to figure out how to built a suitable datalogger, but once it was done, I was able to observe the turbine running well below its design TSR, and nowhere near the most effective speed for the generator. Referring to the generator's power curves, you can see that an output of 600 Watts or even 1kW is possible and quite safe to do from time to time. However, with the 2.4m diameter rotor it rarely made more than 500W. I was simply too conservative on my first set of blades.
There are other reasons... I have replaced the generator several times, too... it's a long story and also on my website if you choose to explore it.
![New Blades for Spirit of Zubbly](https://www.fieldlines.com/index.php?action=dlattach;topic=149797.0;attach=11936;image)
