Author Topic: H-Darreius wind turbines ( VAWT ) !  (Read 150302 times)
MattM and 5 Guests are viewing this topic.
TechAdmin
  • Country: it
Re: H-Darreius wind turbines ( VAWT ) !
« Reply #363 on: May 06, 2024, 08:56:18 AM »
That's a facebook link and they got temporary signatures to show up, since Meta don't want us to use 1mb of their bandwidth and can't afford servers the image signature is scrambled every so often so people can't hotlink images off there.
@topspeed please put the actual images and don't hotlink off facebook image links, as it will only work for a couple of hours and then break itself, sadly not something I can do anything about :( You can rest assured that if you upload the images on our forum they won't go away instead (unless the server and the backups implode but we don't talk about that ;D ).
topspeed
  • Country: fi
« Reply #364 on: May 09, 2024, 07:37:50 AM »
Do image system work now ?
Ulrich Hütter
JW
  • Development Manager
    • Flashsteam.com
« Reply #365 on: May 09, 2024, 09:27:49 PM »
were working on it
JW
    • Flashsteam.com
« Reply #366 on: May 09, 2024, 10:32:59 PM »
 our host had been set at PHP 7 SMF now its at 8.4 or something. they said well be changed to php 7.4
we need to have new forum software. SMF has become too old...
JW
TechAdmin
  • Country: it
topspeed
  • Country: fi
« Reply #368 on: May 20, 2024, 04:47:24 AM »
My new electrical part of the test rig.
15934-0
15935-1
I have not been able to make the new blades yet. I have been able to find and correct several weak points in the old set up.
Ulrich Hütter
topspeed
  • Country: fi
« Reply #369 on: May 22, 2024, 06:26:40 AM »
This displays the colors of the 2. prototype that has been been the most successful so far.
It has inside:
1. kill switch
2. main switch
3. rectifier
4. fuses
5. watt meter
15938-0
Ulrich Hütter
