Author Topic: H-Darreius wind turbines ( VAWT ) !  (Read 155979 times)
TechAdmin
  • Country: it
Re: H-Darreius wind turbines ( VAWT ) !
« Reply #363 on: May 06, 2024, 08:56:18 AM »
That's a facebook link and they got temporary signatures to show up, since Meta don't want us to use 1mb of their bandwidth and can't afford servers the image signature is scrambled every so often so people can't hotlink images off there.
@topspeed please put the actual images and don't hotlink off facebook image links, as it will only work for a couple of hours and then break itself, sadly not something I can do anything about :( You can rest assured that if you upload the images on our forum they won't go away instead (unless the server and the backups implode but we don't talk about that ;D ).
topspeed
  • Country: fi
« Reply #364 on: May 09, 2024, 07:37:50 AM »
Do image system work now ?
Ulrich Hütter
JW
  • Development Manager
    • Flashsteam.com
« Reply #365 on: May 09, 2024, 09:27:49 PM »
were working on it
JW
    • Flashsteam.com
« Reply #366 on: May 09, 2024, 10:32:59 PM »
 our host had been set at PHP 7 SMF now its at 8.4 or something. they said well be changed to php 7.4
we need to have new forum software. SMF has become too old...
JW
TechAdmin
  • Country: it
topspeed
  • Country: fi
« Reply #368 on: May 20, 2024, 04:47:24 AM »
My new electrical part of the test rig.
15934-0
15935-1
I have not been able to make the new blades yet. I have been able to find and correct several weak points in the old set up.
Ulrich Hütter
topspeed
  • Country: fi
« Reply #369 on: May 22, 2024, 06:26:40 AM »
This displays the colors of the 2. prototype that has been been the most successful so far.
It has inside:
1. kill switch
2. main switch
3. rectifier
4. fuses
5. watt meter
15938-0
Ulrich Hütter
topspeed
  • Country: fi
« Reply #370 on: May 26, 2024, 02:29:16 PM »
Wind vane added to study the cyclic current under the swept area.
15943-0
Ulrich Hütter
brandnewb
« Reply #371 on: May 27, 2024, 10:43:25 AM »
scale wise this looks massive!. and what is it even? full steel but with a black lacker of sorts?
I am well impressed and given the the size of the holes you have left for connections I am thinking things will not fly off any time soon.
Anyway what is your intended operation range in terms of RPM of the blades and RPM of the PMA and such?
(Attachment Link)
(Attachment Link)
brandnewb
« Reply #372 on: May 27, 2024, 10:48:52 AM »
yes a test rig :) . if one does not employ one then one is probably an artisan. or foolhardy :)
(Attachment Link)
(Attachment Link)
topspeed
  • Country: fi
« Reply #373 on: May 28, 2024, 03:07:12 PM »
Hahhaaa...it is shark vane to study the currents under the cycloturbine.
This black box is to control the system. It has even a wattmeter...rectifier...fuses... switches...and emergency cut off.
15945-0
Ulrich Hütter
« Reply #374 on: May 28, 2024, 04:58:28 PM »
Reminds me of a Hammer Head .
How are you going to going to study the currents? Smoke machine?
topspeed
  • Country: fi
« Reply #375 on: May 28, 2024, 06:26:08 PM »
Just by looking at the shark below. ;D
Ulrich Hütter
topspeed
  • Country: fi
« Reply #376 on: June 04, 2024, 06:18:15 AM »
Here is in comparison with my foil design the most used foil in Darrieus VAWT blades NACA 0015.
15954-0
Ulrich Hütter
