Thanks Bruce, Adriaan, and MagnetJuice,
I have read Adriaan's report KD 341, more than once, and while I definitely learned some things, a lot of it is over my head.
I agree with what I think is Adriaan's general analysis, that low TSR, high solidity VAWT's have some significant disadvantages which are not always recognized: the blade takes more material than the same swept area HAWT, the lower rotation speed means higher alternator cost (or additional gearing costs), and as there is no furling option, the bearings and mount must be stronger (and more costly) than the equivalent HAWT. These things make me see that to be successful a new VAWT must be made inexpensively from tough long lasting materials (galvanized steel sheet?), and it will need the least expensive alternator and control system that can be made.
Living in the mountains of BC, there is a substantial wind resource but it is stranded at the tops of mountains, and as I understand it, largely inaccessible to modern HAWT's due to the rapid wind shifts and turbulence, and so, if I can get over the first two hurdles I am hopeful that it may find some utility locally. It's my understanding that the mountains are largely inaccessible to HAWT's of any size, due to wind shift and turbulence issues.
I'd like to know more about the venerable “Windsideâ€/GUS and the alternators they use. They have been in business for a long time. Their original claims were that their rotors reached Cp's of 0.21, however they have erased those claims and it's my understanding that purchasers found them to produce much less than 50% of expected power. Their alternators are custom made, and it's my recollection that they used to sell them for use as very low speed high torque alternators. They've gone through a lot of changes, and their website no longer lists them for sale. They claim to be low or zero cogging, but seem to be fairly conventional radial flux machines, however they are very heavy!! 38kg for a .5 m tall and .3 m diameter unit, with a Fiberglas blade!. The blade should be light, less than 5kg, so around 30kg of alternator and bearings! I think they are using ceramic magnets, but I'm curious as to the geometry that gives them low cogging. I have a bunch of 1â€x1â€x6†ceramic magnets, and it's tempting to try to build a radial flux machine,,,, but I'd better keep on track for now.
