Author Topic: 295W Canadian Solar panels, unused, $150 each  (Read 6539 times)
TheEquineFencer
« on: September 15, 2019, 10:57:06 PM »
295W solar panels
Price: $150.00 USD EACH
I have (31) 295W solar panels I need to sell to work on some other projects instead of expanding the Array I have running to my shop now...
They are new, unused or mounted. They were uncrated then stored in a farm building. They are identical to the ones TheSolarStore sells for $276 individually.
Local pick up.
Mechanical Data
Technology: Monocrystalline (Mono)
Dimensions:
65.00 x 39.10 x 1.57 inches (CS6K-295MS-All Black Dimensions)
Weight: 40.10 lbs
Cell Arrangement: 60 (6x10)
Front Cover: 3.2mm Tempered Glass
Frame Material: Anodized Aluminum Alloy (Black)
Junction Box: IP67, 3 Diodes
Cable: (4 mm² (IEC) or 4 mm² & 12 AWG 1000 V (UL) , 1000 mm (39.4 in)
Module Connector: T4 Series or PV2 Series
Operating Temperature: -40°C to +85°C
Electrical Data
Nominal Maximum Power (Pmax): 295 Watts
Optimum Operating Voltage (Vmp): 32.30 Volts
Optimum Operating Current (Imp): 9.14 Amps
Open Circuit Voltage (Voc): 39.50 Volts
Short Circuit Current (Isc): 9.75 Amps
Module Efficiency: 18.02%
Maximum System Voltage: 1000V (IEC) or 1000V (UL)
Module Fire Performance: Type1 (UL 1703) or Class C (IEC 61730)
Max Series Fuse Rating: 15 Amps
Application Classification: Class A
Power Tolerance: 0 / +5 W
__________________
...All my wiring is approved by Undertaker Labs....
https://www.facebook.com/FloydsShopbarandgrill/
TheEquineFencer
Re: 295W Canadian Solar panels, unused, $150 each
« Reply #1 on: June 26, 2022, 01:36:43 PM »
Sold
