Author Topic: Quantum2020 VAWT Vertical wind turbine  (Read 744 times)
vawt
« on: December 10, 2019, 02:50:36 PM »
Quantum2020 VAWT
"My VAWT, there are many like it, But this one is Mine"
Hello everyone, I am back!
i just want to inform every one that i have restarted my VAWT project with a twist.
after creating my Column VAWT design, i realized that i could not control the shake.
you will have to watch vid
Column R 20
to see the issue.
shortley after, i did loose control of it, i tried to rebuild it, but still same issue.
SO, i sat on it, and I had many though experiments unitll i got it.
i created a vawt that changes shape based on air speed.
it will compress so the blades will tilt away from the wind to slow it down.
I tapered the blades to maximize efficiency,
the way it shift from the wind is to have the lower disc rise up.
i am in the process of controlling the rise of disc.
3 options to control the rise and the rise is based on the future PMG VS RPM.
option#1 weight on lower disc
option#2 springs on my tube arms (you wll see it in vids)
option#3 a twist in my tube arms, so it struggles to go up but easy to drop, so far i am using the twist.
please go here and give me your support.
it took over 36 blade design to come up with the correct one.
I cant seem to be able to stop, i know by know i could have bought myself a very well done turbine, but where is the fun in that!, besides, i know most of you likes to see different approaches.
please see my
regards
Sam
« Last Edit: December 10, 2019, 03:32:35 PM by DamonHD »
Re: Quantum2020 VAWT Vertical wind turbine
« Reply #1 on: December 10, 2019, 03:38:49 PM »
VAWT;
That certainly is a different one!
Are these free flowing? Or is there a PMG under that slice of wood?
Cheers on the build!
vawt
« Reply #2 on: December 10, 2019, 04:03:17 PM »
at this time they are free wheeling, i do not have the specs i need to create the perfect pmg, or even find it off the shelf somewhere.
i8 need to establish the RPM vs EXTRACTING WATTS.
my plan is to have a high voltage pmg, i want to extract power starting at 180rpm
i will be using a wind Mppt controllers with 48vdc battery
the Mppt will receive 90vdc at 180rpm anything above that wil be converted to watts by push it in the battery at 50vdc
anyway, i still need to setup and test all that. at this time i want the VAWT design to be stable, so far it is.
sam
« Reply #3 on: December 22, 2019, 08:57:36 AM »
good to see you posting again .
