Author Topic: Power inverter driver board needed  (Read 2836 times)
fabieville
« on: June 29, 2020, 12:09:19 PM »
I bought a power inverter 2000watt 24v at 120vac version off ebay. The brand is KR Power and the driver board got damage.
do you know where can i get it to buy? or if someone has a similar one to my one they can open it and tell me the I.C numbers that are on the board so that i can try and replace them.
I see a part # on it which is D 85773
noneyabussiness
Re: Power inverter driver board needed
« Reply #1 on: June 29, 2020, 06:58:14 PM »
Looks like a common eg8010 board
#Aliexpress AU $4.76  11%OFF | GREAT IT 5V DC-AC Pure Sine Wave Inverter SPWM Driver Board EGS002 12Mhz Crystal Oscillator EG8010 + IR2113 Driving Module
https:// a.aliexpress.com /_dZztUgi
Take the space out after .com and before a. as i cannot post external links...
fabieville
« Reply #2 on: June 30, 2020, 05:13:22 PM »
so do you think that this board that u suggest will work even thou mines has 16pin and this one has 17pins.
should i discontinue one of the pins and if yes which one should i remove or do i have to tie one of the pins with another pin.
can someone please tell me how to configure this board so that it can work.
clockmanFRA
  • Country: fr
    • Renewable Energy creation
« Reply #3 on: July 01, 2020, 02:40:03 AM »
Hi Fabieville,
In my Opinion the first photo you have shown, does not have the 32pin 8010 PWM Chip, ie it is not a EGS002 or the EGS003 plug in board.  But does look like it has 2 FET drivers, a strange 20 pin PWM chip ? and a Op amp etc.
The Chinese have done many many similar plug in boards for small inverters, and over the years i have seen many variants of plug in control boards.  However getting an actual bonifida replacement may be extremely difficult.
Have a search on alibaba aliexpress etc for small inverter boards that have plug in control boards, and spend some time looking at the plug in boards in close up.
Sorry i can not be more helpfull.
3 Hugh P's 3.7m Wind T's (15 years) .. 5kW PV on 3 Trackers, (11 yrs) .. 25kW PV AC coupled to OzInverter MINI Grid, back charging AC Coupling to 48v 1300ah batter
MagnetJuice
« Reply #4 on: July 01, 2020, 06:04:59 PM »
favieville,
I did a search and this is the closest that I can get to your board.
Your board has 16 pins but it looks like one pin is cut off.
This one has 15 pins and has a schematic, hopefully you can use it.
The board number is "PIC16F716 IR2110S" Search for that exact number.
It is sold on ebay, Alibaba and AliExpress.
Ed
