I have been studying a really neat paper
https://ietresearch.onlinelibrary.wiley.com/doi/full/10.1049/iet-rpg.2019.0908It is about coil dimensions to magnet dimensions. And how improperly formed coils that bulge out reduce output by
as much fifteen pecent! And it can introduce knocking or vibrations.
Basically, the bottom line is, to maximize flux capture, the coils must be 180 degrees to the magnet or bad things start.
So by this science study, I should be using rectangle coils. BUt, that isnt very conducive to a disc layout
Is it possible to alter the field shape with additive engineering?
What I am thinking is that I really want to use trapazoid magnets to get optimal results and performance.
And to accomplish that, I was thinking up a method to turn rectangle shape magnets to trapazoid
And to do this, I would 3d print the size of the trapazoid magnet, and to the thickness I require, a hollow shape.
And stick two magnets in it , centered. And than use steel wool which is really magnetic, and mix it with epoxy so its really thick
with steel wool clippings. Clippings as fine as I can make them also.
And than pour it over the magnet, until I get desired depth and shape. Once epoxy is set and really hard, I should have a magnetic field shaped
like a trapazoid. Has anyone ever tried such a thing? I have been researching it and I think it may be promising.
I think I am going to go ahead and try it with a teensy 4 pole generator.
