Author Topic: Making large PLANTE lead acid Batteries.  (Read 21419 times)
Astro
Re: Making large PLANTE lead acid Batteries.
« Reply #66 on: March 13, 2022, 03:17:49 PM »
Ok a quick question. I was reading where and it may have been mentioned in this thread, that you can expect about 1 AH per square inch of lead. I understand that is why the roller and grooves are important to try and maximize that number.  What I am unsure of is, you obviously are going to have 2 plates minimum and for home made 2 plates is the easiest. Those plates will have equal amount of square inches. I assume the 1 AH per square inch is from one plate, right?
 So say you had 100 square inch pos plate and 100 square inch neg plate for a total of 200 square inches. But that is a 100 ah battery, and not 200 ah, correct??
Sorry I know it is a dumb question, I just want to make sure I understand 100% because obviously it affects the numbers when figuring out what to build and the cost of what to build.
Thanks.
Okay, some where in my posts i have mentioned a rough figure per sq inch, but this depends on the original thickness of the lead that you are trying to turn the surface into lead oxide.
A cell, is for me in my calculations, when one lead sheet faces another lead sheet in a sulphuric acid mix of 15 parts water to 1 of 80% pure sulphuric acid. Obviously the lead plates will be double sided use, but the end plates will only need roller ribbing on one side.
And here is the crux of the matter and my experimentation procedures  The thicker the lead, the less capacity the lead cell will have. I think 'Dinix71 has eluded to this in his post on the 9th March. ie, the thinner the lead sheet the quicker the oxide can form, but then the life of the cell is short as a modern commercial battery, so hence me going for a 2.24mm thick lead sheet at first and seeing if i hit the sweet spot, although i may have to increase that thickness to double that, but wee will see.
The roller process adds 2 main objectives, yes the actual surface area that turns to oxide will be greater that just bare Lead sheet with out any indentations. Also the roller ribbing will allow the oxides to form in such away as to stop the oxide from just dropping away if the cell is disturbed.
 In general, with commercial batteries the grid matrix structure holds the oxides and a stiffener spacer is each side of each lead plate to hold the oxides as long as possible before the oxide crumbles away to the bottom of the batteries, hence the plates are wedged into the battery case.
The second objective of our roller processes is to strengthen the lead sheet by allowing a border around the outside of each lead sheet.
100ah could be for one cell, but a minimum of 6 cells joined in parallel to get the Ah rate higher, However 6 cells is best, any more and internal resistance starts to come into play with the figures, and with 6 cells its about the max i have designed the case to handle expansion from the cells.     We do not want the battery case just to split after a few years off use.
For the size I am making with a standard Plante design, and my calculations/ figures suggest about a 450ah with my 6 cells at 2v.  However, because of the roller being used i expect higher figures of Amp Hour, how high in real conditions has not been proven yet.
As you can now see there are lots of variable's at play here so I am using my mechanical engineering skills and that all important empirical evidence to push the Plante battery concept into the modern age.  And also give us a good all round LONG LIFE lead acid battery where weight is not a concern but resilience, longevity and cost effectiveness is..
I trust this helps.
 Now you really have my curiosity up on this project. I went back and looked and your plates come out to be about 8.75 inches by 24.75 inches if I recall the numbers I converted. that is about 216 square inches. With 6 positive plates per cell, that is 1,299 square inches of positive plate. I get thickness plays a part in the calculation and the article I was reading that mentioned said "you can expect about 1 ah per sq inch" did not have the specs for the battery all spelled out. Not that I can remember anyway.
 I think making a cell for renewable energy and not for an auto, would mean that the battery is not going to get disturbed as much and so we do not have to worry about that as much as a battery for other applications. I also thought I read somewhere one time where the thicker plates are used in batteries that provide and receive higher amps. So the thickness of the plates for a battery like you are making and for the application, might not have the same requirements. Many car alternators charge at 100 amps which is way higher then most of us are charging at. Most cars can require 100 or more amps to start but that is only provided for a few seconds or cca rating.. In our application we go by amp hours over a long period of time. That said it takes about 220 amps of 12vdc to make 20 amps of 12vac. I can not readily find the amperage of lead for it's dimensions. It seems to me that the biggest concern in this project is going to be the right dimensions of the lead for how many amps you intend to draw from it for longer periods of time. OR the sweet spot as you called it.
 I am sure many of you knew all this, but maybe some of you did not. It also helps me to talk it through, so I understand it all to the full extent.
« Reply #67 on: March 14, 2022, 02:53:17 AM »
a typical car battery has 7 or so plates that are on the order of 6 by 7 inches, for 50 amp hours of useable capacity perhaps 100 when brand new.
a typical 5 amp hour agm is about 2 by 3 inches and there are 4 positive plates and 5 negative ones iirc. there might just be 3 positive plates and 4 negatives.
anyhow this is a range of 7-10 square inches per ah for the agm and about the same for a car battery.
i don't know how anyone can expect to get 1ah per square inch.
clockmanFRA
  • Country: fr
    • Renewable Energy creation
« Reply #68 on: March 14, 2022, 03:39:11 AM »
For a PLANTE cell design the 13off lead plates at 210mm x 530mm x 2.24mm thick will give me about 550ah fully formed, thats about 60kg or in your speak 132 lbs for one 2v battery.
 Probably more if the grid matrix grooves are consistent. A modern forklift version of the same size will be over double the ah.
My reply to a question on another forum where some one is experimenting with a simple cell.
Yes Bryan1, what your doing is the basic cell arrangement.
I have seen this arrangement in early 1900s manufactured Master Electric clocks where 2 lead plates are dug into the ground outside and a 1.5v is produced to energise a coil every 15 seconds or so, to impulse a mechanical pendulum. Those plates are about 18 inches by 18 inches and 1/2inch thick. Once a week the owner would water the plates that were buried in the ground.
I personally experimented with your shown/photos basic concept about 15 years ago. I could get the volts up but the amperage for each cell was extremely poor and therefore discarded this simple cell method.
As regards acid, yes there are alternative acid/alkaline etc for batteries, but for me i will stick to 15 to 1 sulphuric acid, as we need to self form the lead plates for the PLANTE design.
Its the lead oxide on the surface of the lead sheets that gets the amperage up.
Commercial batteries makers use lead oxide pastes that are mixed with several other secret ingredients and held in a lead mesh matrix that form the positive and negative plates.
The PLANTE battery cell i am trying to produce has fine pressed grooves in the surface of all plates. This then allows the first 0.6mm of the plate surface to form into the correct Lead oxide. Basically the surface becomes spongey as the lead is transformed with the charge and discharge and swap the positive and negative plates around. This is normally about 30 to 40 times. Then the final charge will set the battery to what is positive and negative.
The grooves are the modern twist to the PLANTE battery and the charge and discharge regime are also a modern twist. But the grooves need to be within parameters. I have some test results that show the sizes i have as suitable to get the lead oxide to form correctly, and also hold the lead oxide in position.
Once the battery is formed then the oxide will get thicker as the battery is used and the amperage will slowly rise. However there is an offset against the thickness of the lead and its structural integrity, again this is part of my test procedure.
 Eventually, 30 years or so, the lead positive plates will completely turn to mush lead oxide, and the lead plate will just collapse. Then its my intension to remove the plates and replace with new positive plates and start the charge and discharge process all over again.  Although in 30 years or so i may not be around.!!!! But my boys will be, so hence me doing a book about my batteries.
Most of you will know that its normally the Positive plates on any lead acid battery that just crumble away to nothing and the battery ceases to be useable battery.
Its the commercial boys and the consumer wanting high amp hour at minimum materials but then sacrificing longevity of the battery by using ready formed lead oxide in their lead matrix frames that is not very structural stable.
Those 30 to 40 Charge and discharge and reverse process with the PLANTE are very important and sets the final battery amp hour rate. Charge must be precise and discharge must be precise. Again i have some preliminary data on this, but at present will not give any figures until i have well tested the process.
Again these PLANTE batteries I am making need to be as efficient as possible, easy to make, but safe, with readily available materials. And any specialist bits like the stainless steel roller for the grooves in the lead plates must be easy to make and give consistency to each lead plate and yet require simple skills to operate.
Another of my replies to someone making a single cell.
There are a lot of things happening with the PLANTE cell.
Firstly, with a anode plate and a cathode plate, ie one lead plate and another lead plate facing each other this is called a single cell, the usable voltage of this cell will not exceed more than 2.3 volts, in practice its about 2.22volts.
Secondly, on bare lead when you first fill with acid solution the cell becomes live, the acid solution is fully charged ie, its specific gravity is up at the appropriate levels this will change as the cell is discharged.  Normally its about 1.265 and during discharge it will drop to about 1.150 and the electrolyte will only be 17%.
 When recharged the battery will rise again to 36% electrolyte and about 1.265 again. As the battery gets old in normal batteries, the specific gravity will drop as the internal plates deteriorate and the useful amp hour rates also drop.
 For our PLANTE its the other way around. Our initial Amp Hour rate is not as good as a modern commercial battery, ie only about 1/3rd but over the many years it will be used the battery gets better until eventually all the lead plates internally are just a oxide paste. So we need to hold that oxide as long as we can, and not allow it to short out the cell within the battery itself.
Thirdly, when first filled you will see that the Cell is Bi- sexual, ie, put your voltmeter leads on each plate, then remove the leads and swap them around and hay presto it gives  voltage the other way around as well.
Okay so we need to form the correct oxides to form on the correct plates. So to form we  charge at 20% to 23% voltage of the 2.3 volt cell and at 10% to 13% amps of the rated Amp hour capacity of that cell.
12 volt batteries in general are normally 6off 2.22v voltage cells with each 2.22v cell have about 7off 2,22v cells parallel connected to get the Amperage out put up of each of the 2.22 cells in the 12v battery.
Rated Amp hour capacity of your 2.22v cell for a PLANTE battery is defined roughly by surface area of each POSITIVE plate in that cell. So for your plates of 270mm x 180mm and at say 2mm thick, we need to know the plate weight to get the surface area that we can form to get the amp hour.  However a rough guide for your plates of one cell would be very approx. about, 7 to 9 amp hour for a kg of your size.
Discharge rates for PLANTE battery plate oxide forming.
Each of the 30 times minimum charge and discharge should be the same rates to form the correct Oxide. And remember the polarity should be reversed on each charge.
On the 31st charge you will then make the positive plates positive from then on.
Discharge during the initial oxide forming procedure should be about 10% of the battery capacity in voltage and amperage.
Whoops i have the oxide forming rates slightly wrong when i went through my figures. Sorry about that, but i wont edit the above as this is very much an experimental procedure so i always like to show mistakes, as i believe it helps others, and no one is flipping perfect.!     and its good to see if Bruce is still awake, hahahaha
Charge rates are slightly wrong in my above posts, sorry.
For our PLANTE battery designated at 1.5volts we need to .........
CHARGING the PLANTE battery.
Okay so we need to form the correct oxides to form on the correct plates. So to form correctly for the best attributes for the oxide, we charge at 20% to 23% over the designated, designated voltage for each of our cells is 1.5v volt cell. And at 10% to 13% of the amperage of the calculated rated Amp hour capacity of that cell.
So for our battery we will charge at 2.43volts and at 57amps.
Remember change the polarity for each of the 30 plus charges as you form the plates.
Discharge at 10% of the cell capacity, so for our 2.22volt 550ah PLANTE battery thats,
2.442volts and 55amps.
« Last Edit: March 14, 2022, 03:53:09 AM by clockmanFRA »
clockmanFRA
  • Country: fr
« Reply #69 on: March 14, 2022, 04:05:49 AM »
Thanks.
At present the experimental phase of a PLANTE battery does not make it cost effective against comercial battery manufactureres.
However for me i need 48 off these 2v PLANTE batteries to get up somewhere near the 1000ah at 48v battery bank. And by 48 i should have got the PLANTE battery build about correct.
You will also find very negative comments from the commercial boys who quote their specs etc and how wonderful there products are and folk who know all the tech numbers etc.
Me i will plod along and publish here and other forums and be dammed.
I have in the past and about to again, upset certain manufacturers and organizations and some have Courts papers against me to not talk about their rubbish concepts and products.
 I am also on other forums as i have been banned for saying what I am doing.
Fortunately, this forum has no connection to the commercial boys that put undue pressure on them.
Thanks Fieldlines.
Astro
« Reply #70 on: March 14, 2022, 02:31:44 PM »
Thanks.
Thanks Fieldlines.
 Which is exactly why I asked if you were going to plate with pb304. The reason they do it that way is two fold. #1 it forms the oxide faster and so you do not need 30-40 charge discharges, But also, that is how they get by with less lead. The reason it is not much more cost effective to build your project is because of the much larger amount of lead you are using compared to them. They use expanded lead or screen type lead, however you want to say it and not a solid sheet and so it greatly reduces the amount of lead needed. Playing with some lead oxide in your plating process can reduce the amount of lead and therefore the cost to build. You can still go with larger plates then they do. You can still go with thicker plates so they last longer.  All the lead oxide will do is bring your battery up to it's potential faster, instead of waiting for the lead oxide to build up over 700 charge/discharges over a long period of time. So instead of waiting 4 years for your batteries to reach peak efficiency, and that is the point you really will need to decide dollar for dollar how your batteries compared to commercial, you will reach peak efficiency much sooner. If you use thicker lead then what they use and allow enough room for shedding, that layer will just shed off exposing a new layer of lead oxide and since they are thicker plates, they will not break down as fast as a commercial battery will.
« Last Edit: March 15, 2022, 12:13:30 PM by Astro »
Astro
« Reply #71 on: March 20, 2022, 12:12:55 PM »
Been thinking a lot about this project recently, while waiting for parts for my project. I have a couple ideas about it all, but am just trying to sort through them and figure out if they are good ideas of not. I know this much, at 4lb  per sq ft sheet (which is about the thickness you are using) and 8.25 inches by 24.75 inches for plate dimensions (I think that is about what you said), you should have 70 pounds or so of plates in this cell (with the 6 pos and 7 neg plates). OR was the 6 pos plates you mentioned being one pos plate per cell? The avg car battery has about 20-30 total pounds of lead, or about 3.5 to 5 pounds per cell. Even large 6 volt batteries that weigh 125 pounds probably have around 70 pounds of lead, or about 11-12 pounds per cell.
 Like I said, it seems like 70 pounds is a lot of lead for one cell. I mean in a few years when you get the oxidation up on all that lead, I think you are going to have a much larger capacity battery then you have projected. If using no paste on the positive plates yields a battery that is only 25% as efficient until it builds up the oxidization on the pos plates, you would need 4 times the lead TO START WITH (like you said it is only going to get better with time). If a large 6 volt is using 11 pounds per cell, 4 times would be 44 pounds per cell and just over half of the 70 pounds you are building.
 I am just running the numbers here, so I understand completely.
 After much thought, I think the biggest obstacle I can find in all this is the cost of a power supply. Because finding something that can put out 2-3 volts at 50-100 amps is not cheap. If it was not for that, I would be more apt to start collecting parts and give it a go.
« Last Edit: March 20, 2022, 01:46:37 PM by Astro »
« Reply #72 on: March 21, 2022, 02:35:00 PM »
Astro;
I think maybe you're missing the point of how & why ClockmanFRA is doing this project the way he is, which certainly neither the cheapest or lightest way.
It's not to beat the major battery builders at their own game. It's not to hurry to get the batteries formed so he can get them connected to his system.
It's to Firstly build them as close to the original build plans as possible and post that information here too (when he finds time, which is why you will not see a rapid response most of the time), this also allows the home-based DIY person to follow along and replicate what he's currently doing.
Astro
« Reply #73 on: March 21, 2022, 06:39:06 PM »
Astro;
 I understand what he is trying to do. I also am not expecting a response at any given time. I have projects that have taken years. Heck by the time it goes from "I am going to do this" to flying is going to take all of a year just for my mill, not counting storage or anything else.
 That said, I would like to understand his plate plans better for several reasons. First being having very long strips and just 3 of them, cuts way down on fab time and skills, tools and such. Second reason is I think you are going to want to put as many amps into charging this battery as you can. That is going to not play well with long strips and will make them want to warp. Personally, I would throw almost enough amps at charging them as you can without boiling or cooking the acid. I would charge by acid temp to determine amps. That tweek in the plating process will form the oxides much faster as it places maximum stress on the surface area of the plates.
 Like I said I have some thoughts on the project, but only sporadic and not totally thought about, because........... it's not my project. I am building a mill. :).
« Last Edit: March 21, 2022, 07:18:24 PM by Astro »
Astro
« Reply #74 on: March 21, 2022, 07:26:03 PM »
Astro;
 That said, we are going to have to design a power supply that puts out 100 amps or so at 0-6 volts or so.  Maybe a control board for an old dc welder????
aka47
« Reply #75 on: April 29, 2022, 07:01:29 AM »
A quick departure from the discussion to say thanks for having this post and the contribution, especially the works of the original poster.
The days of readily available lead acid batteries are numbered. Their cost effective availability is predicated on mass manufacturing and mass demand. Mostly automotive.
I guess it doesn't take much to see that the way technology and automation is going this going to produce a knock on effect on their availability and pricing.
Similar is unfortunately going to happen to a bunch of electronics components. For the same reasons. There is sufficient demand though for other purposes to make this one less of a crunch issue.
On commercial lead acid batteries I fully agree the issue with these for energy applications is their poor lifespan. Although they are initially cheaper than alternatives, once you figure in their life span as a total cost versus storage etc calculation they start to look like a poor option. I did these estimates recently to decide on buying in a quickly available (ish) battery store to better match solar production to energy consumption at home. AN ended up biting the bullet for some large Lifepo4 cells with a higher cycle spec.
So for me personally because of the above, I am very interested in what you are doing here as it has promise to provide a route to self sufficiency both for me and for others, that is independent of the changes that are happening around us.
On volume comparisons ie actual volume versus storage volume, a DIY unit may not be the best, but for a static application it becomes irrelevant so long as there are accessible containers and materials.
I like the idea of the better (more lead) plates as it plays into simplicity, accessibility (Roof flashing) and produces a greater lifespan. I will take a hit on my time and financial expenditure If I don't have to replace it much or again in my life time. We should be lazy like fox's.
Reading through the work that is being done here, and having got a quicker hit on my storage needs to sort me for the interim. I could see me building my next store using the methods above or similar. The longer life makes a big difference once you do a total cost of ownership study versus capacity on any potential solution. Physical size and volume other than as a hit on a materials budget is almost a non issue for static energy storage.
So in summary thanks and keep on with the project and it shoudl take as much time as it needs, it looks awesome to me.
Tolerance is a two way street
aka47
« Reply #76 on: August 03, 2022, 09:52:46 AM »
BTW, where did this one get to.
I was excited by what was being achieved and it seems to have dropped a little quiet. Happy to accept it is me not quite driving the forum correctly tho.
Did it work ??
clockmanFRA
  • Country: fr
« Reply #77 on: August 04, 2022, 12:12:50 PM »
Sorry folks been rather busy here.
Masses of priority projects that need my urgent attention.
The hand roller is real good and works well at producing the correct grooves in the lead sheet.
I am at this moment in my spare time making a simple Base jig and stainless steel strip arrangement for the hand roller tool to form the fine grooves that are constant parallel to each other.  Also for doing the 90 degrees cross grooves.
Have also fleashed out the lead plates holding connectors and the case design is nearly sorted out.
A few pics of the hand roller lead sheet groove tool.
14947-0
14948-1
« Last Edit: August 05, 2022, 02:21:16 AM by clockmanFRA »
« Reply #78 on: August 06, 2022, 09:49:34 PM »
"Manche" printed on the wooden handle...
Are the French in the habit of labeling everything they possibly can?
clockmanFRA
  • Country: fr
« Reply #79 on: August 07, 2022, 04:24:22 AM »
Local Hardware shop here in the 'country'.
Looking at the large stack of wood handles this Hammer, 'Marteau' handle was nice and long and could take my 12mm stainless steel bolt up it,  yet would fit in one hand and the other hand could press down firmly on the stainless steel roller end.
Loads of handles there, but one stand of handles made me smile, 'HICKORY handles MADE IN CANADA'.     hahahaha.!
MattM
« Reply #80 on: August 07, 2022, 09:33:21 AM »
Does it have to be lead sheet or could you dope other sheet material to get the same results?
« Reply #81 on: August 07, 2022, 01:10:16 PM »
The best choice, of course.
clockmanFRA
  • Country: fr
« Reply #82 on: August 07, 2022, 04:30:16 PM »
MattM,
If you read this thread topic you will understand where we are going with this project and how we are improving the surface area in a modern simple way and also getting a better physically holding plates, and hold the appropriate lead oxides as we form them.
JW
  • Development Manager
    • Flashsteam.com
« Reply #83 on: August 07, 2022, 05:04:19 PM »
The thing about LA the plates can have "calcium" on the surface.
MattM
« Reply #84 on: August 07, 2022, 07:34:25 PM »
If you could find somebody with a good Pexto or Roper Whitney slip roller than you could slowly thin out sheets to paper thin fineness with some patience.  Copper could be grown 15% or so before any sign of stress cracking using cold rolling.  You could go 50% with the same copper if you used added heat and a bit of patience.  I imagine that lead is easier.
aka47
« Reply #85 on: August 09, 2022, 05:45:45 AM »
Absolutely no apology for being busy is necessary.
I guess we are all doing stuff in and around our usual day stuff. Great to see where it s at, at the moment.
aka47
« Reply #86 on: August 09, 2022, 05:53:03 AM »
If my understanding from reading the whole thread is correct thin is the enemy of good
in this project. The thinking at the moment seems to be that the lead plates turn into a porus-ish lead/sulfur/oxide compound over time. If there is no lead in the core to hold it together and pass the electrons the resulting mush stops working usefully. So the thickness is directly related to lifespan.
Thick and with an increased surface area through embossing is the desired objective. Kind of makes you wonder if there was some mileage in using a hydraulic jack and half a waffle iron with a stiff enough hard rubber pad to push the lead sheet into the waffle pattern.
aka47
« Reply #87 on: August 09, 2022, 06:02:40 AM »
Oh and while I remember, a cost effective source of expanded plastic mesh may be a Scuba supplier.
We used to use it a lot as a sock over diving cylinders to stop them knocking together and chipping the protective pain layer when they were being slung about or rolling about on the deck of a boat.
I don't remember it being expensive and it was hard wearing whilst allowing the sea water to drain and dry out from around the steel cylinder. Almost definitely worth shopping around though if you were intending to buy a quantity. Someone was making/supplying it to the dive shops.
Googling (other search engines apply) for "Heavy Duty Cylinder Mesh" should turn up enough hits to illustrate what I am referring to.
« Reply #88 on: August 10, 2022, 09:14:43 PM »
Thin plates are also a trade-off between more current (thinner = more surface area) and tolerance of overheating (thicker = less warping).
MattM
« Reply #89 on: August 10, 2022, 10:20:27 PM »
They make copper sheet coated in lead.  I don't think you can overheat that stuff.  But it does come in nice fine thicknesses.
clockmanFRA
  • Country: fr
« Reply #90 on: August 31, 2022, 07:41:28 AM »
Okay chaps, moving to production stage.
There has been lots of design changes to the lead plate arrangement and testing the holding concepts, but after many revisions we are ready.
Getting at a good price 69kgs of 6m long by 440 wide pure lead, thats 24 battery lead sheets.
Each 2v battery will have 13 sheets of the identical size and fastening and connecting arrangements.
Each sheet costs about $7.
In the photo below there is a plywood template for the lead sheets.
On top of the ply template is the stainless steel cutting frame for the cutting of the lead sheet to exact size each time,  and for a 48v battery pack i need 312off lead sheets.
Cutting the lead is 3 passes with a sharp thin  Stanley 1992 blade, works well.
A A2 cutting self healing Matt underneath.
Still keeping the design simple but robust.
I have the  PVC for the case but these can only be manufactured to exact size once the true thickness of the plates will be, as each plate gets a polythene thick sock and a MDPE 12mm square Matt between each plate and cell.
The MDPE garden fence comes in various mesh sizes but 12mm  or 'half an inch' seems a good compromise  at this stage as its stiff so will keep the plates separated yet but will allow very slight movement due to heat, discharge and charge conditions.
Should start production next week.
14982-0
14983-1
« Last Edit: August 31, 2022, 08:16:13 AM by clockmanFRA »
clockmanFRA
  • Country: fr
« Reply #91 on: September 07, 2022, 03:22:52 AM »
Making the lead plates.
Each is 525mm x 220mm x 3mm thick.     20 1/2 inch x  8 3/4 inch by  about 1/8 inch thick.
A few hundred to go.....
14996-0
14997-1
clockmanFRA
  • Country: fr
« Reply #92 on: September 21, 2022, 01:50:55 AM »
Thank you 'Bruce'.
The PLANTE battery  project is  still in progress, but this is breaking new grounds in so  many ways,  so its a gentle design and make,  experiment and test at  every stage of manufacture.
No complicated stuff and i am endeavouring to keep the making process as simple  as possible and without loads of complicated equipment.
Each 2v battery has 13 sheets of lead and that's 38kg of just lead sheet, then we need to cast the simple main bus bars.
At the moment i have started using the hand roller to put those 0.5mm deep lines into the 13 lead sheets, each battery is 13 sheets, but i am  making a simple Jig to keep the roller process simple and accurate as each plate needs to be uniform in its matrix or one cell out of the 6 cells will be uneven in output of its ah.
So now the roller jig has to be thought out, and yet simple for anyone to make. Its done now, but needs testing over and over again, and that it stays where the roller is rolled. 13 sheets for one battery, 24 batteries for a 48v system, hmm that's 312 sheets need rolling accurately.
Actually its only the two end plates in each battery only need rolling on one side only so that's 288 times x 2 , both sides of each sheet giving the roller jig 576 times it will roll a side of lead for a 48v battery pack. So this roller jig is VERY important to get correct.
ruddycrazy
« Reply #93 on: September 21, 2022, 06:04:56 AM »
Hi Bryan,
              Making jig for imprinting the grid on the plates so a rinse and repeat method can be adopted isn't really rocket science and just a bit of thought is needed to nut out the design.
Now to drive the imprint roller it's going to need some grunt so a dual chain drive connected on a shaft at each end of the jig and the chain can be connected to a centre pad that holds the imprint roller. Just use a 24 volt DC truck wiper motor as the power source and speed control will be an easy task. At the end of each stroke we need to index the roller to the next position.
One end of the jig can be connected by a hinge set to the full imprint height and the other end can be an adjuster to set the roller pressure, so either light pressure can be used or heavier so the final pass height is determined.
Anyway first thoughts and in the morning I can sketch up a concept for you to follow, as we have to have a day off tomorrow the yard arm did arrive early this week.
Cheers Bryan
clockmanFRA
  • Country: fr
« Reply #94 on: September 21, 2022, 11:11:04 AM »
Hi ruddycrazy,
If you look earlier  in this  topic i  decided to do a hand roller at  about 25mm  wide, as at  this width and one hand pressing down firmly and the other on the handle the 0.5mm deep at 0.5mm wide and spaced at  2mm work well. Its just ensuring that the roller stays on course on each pass. Then you do the same at 90 degrees to create a grid .
This way its very easy to  do by hand and no big machines are used. Also lead is easy to deform and that's why i stuck with just 25mm widths with the roller, so deformation of the lead is minimum.
Its about  making these with very basic equipment for the ordinary RE person  wherever they are on this planet.
Mrs got me an old DEUTZ  D30S,  made 1963, 1700cc twin air  cooled diesel  Tractor, so i can now also cut our 8.5 acres of grass. As if i  haven't anything much  to do, yea right. lol
« Reply #95 on: September 22, 2022, 10:19:20 AM »
"Mrs got me an old DEUTZ  D30S,  made 1963, 1700cc twin air  cooled diesel  Tractor, so i can now also cut our 8.5 acres of grass. As if i  haven't anything much  to do, yea right. lol "
I thought you already had quadrupedal echo-friendly lawn munchers? They not holding up their end of the bargain?
 >:D
clockmanFRA
  • Country: fr
« Reply #96 on: September 22, 2022, 11:27:31 AM »
All got that dose of shollinberg lurgy and all offspring died at birth or soon after.
We will get some more, but what we want on our terms, the last lot of sheep were 'Rouge West' a french breed. But they were ruffians.
clockmanFRA
  • Country: fr
« Reply #97 on: February 15, 2023, 11:33:54 AM »
Feb 2023. How to make your own, 440amp hour, PLANTE lead acid batteries.
The more you use a PLANTE battery the better it gets, and it lasts many decades.
The project is still progressing.
Just a few photos and updates.
We have 14 lead plates in each battery the photos show the Lead plate surface roller making the 0.5mm depth  grid pattern into each surface and on both sides.
I am trying to keep this process simple and can be done with simple tools by anyone, anywhere on this Planet.
Remember we want the surface of the lead to turn to lead oxide so the amperage can be good from the word go, rather than awaiting many years for the battery cell to get to 440amp hour.
Also, as you can see with this simple modern method, we increase the surface-active area considerably by using the roller method.
15266-0
15267-1
15268-2
clockmanFRA
  • Country: fr
« Reply #98 on: February 15, 2023, 11:39:26 AM »
Rolling the grid vertically.
15269-0
15270-1
15271-2
