Author Topic: How to Reduce the standby current for Low Frequency Power Jack inverters  (Read 1011 times)
fabieville
I have a 10,000watt power jack 48v LF 120/220vac split phase power inverter with high standby current . I don't want to use it in power save mode.
I want to use it in normal mode and still have a low standby current draw.
Can I reduce the standby current significantly by installing an inductor inside and if yes where exactly should I place it and does the power jack comes with a built in inductor which I would have to bypass?
Here is a link for the inverter:
https://www.ebay.com/itm/265233206239?_trkparms=amclksrc=ITM&aid=1110002&algo=SPLICE.SOI&ao=1&asc=20200818142836&meid=da5f554349504b65a72b038052e135e9&pid=101197&rk=1&rkt=12&sd=265380105655&itm=265233206239&pmt=1&noa=0&pg=2047675&algv=PromotedSellersOtherItemsV2&brand=Power+Jack&_trksid=p2047675.c101197.m1850&amdata=cksum:265233206239da5f554349504b65a72b038052e135e9|enc:AQAGAAACAAzjp2g73yhKyw7FW8C0Mv82d9BP%2BX939%2BkM7SEOPIzgzNLRB7I0bCT0m1cjCaNh%2B7EIWjZaGG46zCQFFgrXUfRbvfu9d%2F%2B4oUP95JkwGujHFaMeTGcp0img0amlzEnpd2dL2X12IDbGTxrNeo9vFbfL%2BxknGoWEY2hy3woh4FkKjvd%2FqeGQ%2BQhejO3eFsLJNp9OuZ9z3yOX%2FQi%2B6OtE2IlH30%2BNvTgMlAyL8tHYEklt5AnfsdNhY7q9l4vz1VRQCHTHzQ70trMCZCBetLRYsYrIez9%2FqFk4sqauCFVkNxBfkJLgo1HZdwwDAiY4pgdafgCjqTk30mMf1d4Aj8GJi6C%2BKVs1m%2BELuijnhIw%2FtRi3A31xVr7mu13dHq9fenvdAVLXdMd9KLSnybfDSD4Jyykh2fdpGZHJmlkGgMLuMhbIpLg5sqZsldEqj%2Bv7xkFmA%2B4ZQ88iXS1CHUTQ2lfzeP%2Fo2wK4n2xmgCzytu3NdQslR2sUA%2FMmwSxJFVPcZyINEkCpFD2lvwa6fHJgz%2FvkEBGW8STAwM7xQN6%2BfksrBX%2FZWqwrIjqX2rn%2BX5dv4mWNBr53Of0wITqB%2BNww%2Frhg2OWRPkzyvz4VxLVKVDdO2syXBARaUEeMcPQkNc3NTEQhMdAgyvGZrrud0P7fVy%2BnDxEjV9maGZiLlKU%2BfIbKdxfG|ampid:PL_CLK|clp:2047675
Here is the link for the inuctor:
https://www.aliexpress.com/item/33044834301.html?spm=a2g0s.9042311.0.0.27424c4dIyZcxr
boB
    • boB
Re: How to Reduce the standby current for Low Frequency Power Jack inverters
« Reply #1 on: November 07, 2021, 04:56:20 PM »
It might just help !
What is the DC idle current at 50V now ?
boB
fabieville
« Reply #2 on: November 08, 2021, 12:23:09 PM »
3 amp
« Reply #3 on: November 09, 2021, 05:14:45 PM »
I did not see much of a power reduction when modifying a APC ups with a powdered iron inductor. in fact with a few dozen T-106 green-blue cores (used as chokes in computer power supplies) it actually increased consumption.
saw quite a bit of power reduction from typical ferrite cores as an inductor.
i made a swing choke by taking an "e" core but tilting the core such that the air gap was only on one side. this should provide some inductance even at high current while not saturating the whole core. the core i used was about 1 square inch cross section and something like 8 turns, i forget the gap but it wasn't much.
anyhow most ferrite cores found in smps are suitable. since the bulk of the wasted energy (by total kwh) is at idle, it may not matter much if the core saturates at high current.
gap the core about 1%. this gives a permeability of about 100. so a typical 2" long magnetic path gets a .020" gap
« Last Edit: November 09, 2021, 10:48:08 PM by joestue »
