Author Topic: Inverter to high output panels  (Read 779 times)
guruji
« on: April 11, 2022, 05:20:25 AM »
Hi guys I have 34v output solarpanels and want to hook it to a 12v-22v inverter. What should I do to lower their voltage?
Thks.
mab
Re: Inverter to high output panels
« Reply #1 on: April 11, 2022, 09:57:29 AM »
You could try looking in the connection box on the panel - if it gives access to the midpoint of the panel - i.e. 17v then it may be possible to electrically split the 34v panel into 2 x 17v panels and connect in parallel.
Otherwise it may be simpler trade in either  the inverter or panel for compatible ones?
Or use an MPPT controller to drop the voltage - but this may be an expensive solution and electrically inefficient as your converting voltage twice.
guruji
« Reply #2 on: April 11, 2022, 10:50:43 AM »
Hi mab thks for response. This is just for temporary usage cause had another inverter and trying to fix it but cannot find equivalent mosfets to it ITA25N50R.
Thks.
« Reply #3 on: April 11, 2022, 01:08:58 PM »
MOSFET is a 25n50R(r maybe reverse pin out?) a Chinese part... good luck finding one...
